Weber Swap
9 replies to this topic
#1 Birddog
Birddog
    New User
  • PipPip
  • 17 posts
  • Stuarts Draft,Va.
Posted 07 February 2004 - 09:54 PM
Gettin ready to swap to a weber,but I have a few questions.Is the connector for the electric choke the same or will it need need to be modified?What needs to be added if I get a carb with the water choke.The adapter plate,does any one have a picture or sketch of what it looks like.I could probably make it if I could see one.Does the coolant hole on the manifold get blocked off by the adapter plate or is there a hole for that too?And finally does any one have pictures or diagrams of the hose connections.
Thanks
#2 Birddog
Birddog
    New User
  • PipPip
  • 17 posts
  • Stuarts Draft,Va.
Posted 07 February 2004 - 10:25 PM
I guess I should have mentioned what I was puttin' it on.84 gl hatch 4wd.It doesn't have power steering.so I can put it on straight,right?Bear with me I'm still kinda new to this site.Have been reading for weeks but not posted much.thanks for the info
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,690 posts
  • Portland
Posted 07 February 2004 - 11:55 PM
Yep - put it on straight.
#4 Mike W
Mike W
  • 706 posts
  • Seattle
Posted 08 February 2004 - 12:43 AM
If my attached image works, it should give you the hole locations you need. It's EMPI brand adapter made to fit the Hitachi intake like you'd have on your '84 Hatch.
#5 Mike W
Mike W
  • 706 posts
  • Seattle
Posted 08 February 2004 - 12:47 AM
The other side of the adapter and gaskets.
#6 Mike W
Mike W
  • 706 posts
  • Seattle
Posted 08 February 2004 - 12:57 AM
And the gaskets (like you really need measurements for gaskets.)
#7 fangster
fangster
    USMB is life!
  • 194 posts
  • Brisbane, Australia
Posted 08 February 2004 - 05:32 AM
I just did a Weber swap on an EA82. Cameron's site is the following - if it still helps :)
http://homepage.powe...ber_dgav_32.htm
#8 Skip
Skip
    Flatuous Blather
  • Moderator
  • 8,991 posts
  • Latrobe, Pennsylvania
Posted 08 February 2004 - 08:29 AM
WHOA!! Mike, let me be the first to thank you for the most excellent dim work on the adapt. and gaskets.
Very nicely done!!
#9 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 08 February 2004 - 12:18 PM
Local (for me) supplier for webers, parts, and gaskets. But they have an 800# and do mail-order also.
http://www.carbsunlimited.com/ in Fife, WA (just off I-5).
#10 Mike W
Mike W
  • 706 posts
  • Seattle
Posted 08 February 2004 - 12:29 PM
Yeah well what sucks is that I made those pics a couple years ago and forgot I had 'em. I should have shared a long time ago but forgot they were on my harddrive. Maybe they could they be added to the Weber installation info on the USRM?
For those making their own adapters from scratch, a decent bimetal hole saw is all that's needed to bore the big hole. Works quuite well on soft aluminum.
