99gtott Posted July 7, 2010 Share Posted July 7, 2010 This might seem like a weird question to some but i'm wondering if there would be any benifits to mating the motor and trany outside the vechicle and droping them in together? I have the trans out and wondered if this was possible? thanks! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 7, 2010 Share Posted July 7, 2010 It can be done but there isn't much benefit to it. Install the trans first then mate up the engine. GD Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 8, 2010 Share Posted July 8, 2010 i like bolting them together outside and installing them as a unit, but you gotta have lots of room to lift and tilt things around, it's a tight fit but i've done it on EJ25's too. Quote Link to comment Share on other sites More sharing options...
davebugs Posted July 8, 2010 Share Posted July 8, 2010 Even an auto? Quote Link to comment Share on other sites More sharing options...
subaru360 Posted July 8, 2010 Share Posted July 8, 2010 Put the trans in first and then the engine. You can remove/install them together, but it is 10x's harder. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 8, 2010 Share Posted July 8, 2010 Even an auto?yes on DOHC, haven't done a SOHC that way but would assume it's similar. you have to get a really crazy angle going to pull the entire lump up and out over the radiator cross member, but it'll work. they look way more vertical than horizontal, it's totally cumbersome and probably not a good idea or likely to be preferred. for a first timer or without equipment/space it would likely be a debacle. Quote Link to comment Share on other sites More sharing options...
davebugs Posted July 8, 2010 Share Posted July 8, 2010 Yea - I'll stick to 2 pieces. I've passed on auto cars with the engine or TC locked up for this reason. Just wondered how dificult/practical it was. I believe I'll continue to pass them up. Quote Link to comment Share on other sites More sharing options...
