'95 Legacy Outback Transmission Rebuild
7 replies to this topic
#1 Sangerboy
Sangerboy
    New User
  • PipPip
  • 23 posts
  • Ventura County
Posted 30 October 2010 - 04:14 PM
It's time to get into the manual transaxle on my '95 Legacy Outback (I'm the original owner 280K miles) Does anyone make or offer a rebuild kit? (Seals,syncros etc) It has started leaking gear oil and will not stay in 4th gear, 1-2 shift has been sketchy ever since my oldest daughter brought it back from college when she was using it a few years ago. Would like the convenience of a kit, don't really want to go to the dealer and order a bunch of individual parts. Thanks for any help. Greg
#2 Gloyale
Gloyale
    It's a sickness
  • 10,835 posts
  • Corvallis, OR PNW
Posted 30 October 2010 - 05:56 PM
There are no kits that I know of.
I ussually tear it apart, inspect and replace bearings that need it. New seals everywhere. Syncros you can just have lightly bead blasted and they will work again.
4th gear popping out means you definately need the Upper shaft rear support bearing.
#3 lmdew
lmdew
    _______
  • 3,763 posts
  • Colorado Springs
Posted 30 October 2010 - 07:46 PM
Good used one and you are done.
#4 Sangerboy
Sangerboy
    New User
  • PipPip
  • 23 posts
  • Ventura County
Posted 03 November 2010 - 04:50 PM
Is the upper shaft, the pinion drive shaft or the main shaft?
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,923 posts
  • Portland
Posted 03 November 2010 - 04:52 PM
Upper is the main - pinion drive shaft is the lower.
Noisy 5 speed's are usually a result of main shaft rear bearing failure.
Typically cheaper just to find a used one - the parts will run more than a good used tranny with 100k on it.
#6 Sangerboy
Sangerboy
    New User
  • PipPip
  • 23 posts
  • Ventura County
Posted 03 November 2010 - 07:08 PM
Thanks for the input and excellent advice, I will look for a replacement tranny.
#7 GeneralDisorder
GeneralDisorder
  • 21,923 posts
  • Portland
Posted 03 November 2010 - 07:26 PM
Try here:
www.car-part.com
I have bought a numer of engines and trannys from the yards that list on there - all excelent deals.
#8 idosubaru
idosubaru
  • 24,013 posts
  • East Coast
Posted 03 November 2010 - 08:24 PM
+1, for a used transmission. they don't fail enough to warrant a rebuild for me.
save your old one or at least remove the rear extension housing with the center differential. if you get torque bind then you can swap that, doesn't require trans removal to swap either.
