Crankshaft Position Sensor
7 replies to this topic
#1 dbarber
dbarber
    New User
  • PipPip
  • 11 posts
  • West Chester, PA
Posted 05 March 2004 - 12:20 AM
Hi all. I've been lurking for a while, but now I have a problem, and I sure hope that you can help me. I did a search, and didn't find anything.
I have a '95 Legacy L Wagon 80,000 miles, with 2.2L engine and 5MT. I bought it last fall from my brother. Today, while I was running errands, it refused to start. :mad: It would crank over, but no spark. A few minutes later, it started, but I had a CEL. I went to AutoZone, and they said it was the Crankshaft Position Sensor. I had the exact same thing happen a couple of months ago. Now that it had happened twice, I am worried about it.
Will this continue to happen until I replace the sensor?
Should I just replace the sensor, or there some other thing causing the sensor to read bad?
Should I try to clean the sensor, or just replace?
Thanks in advance for any and all help that you can give me.
#2 avk
avk
    My Outback is bigger than yours
  • 965 posts
  • Somerset County, NJ
Posted 05 March 2004 - 07:15 AM
This is common and replacing the sensor would be the first thing to do, along with the camshaft sensor which is of the same design.
#3 applegump
applegump
    Eat, Live, Breath Subaru
  • 316 posts
  • CH
Posted 05 March 2004 - 08:44 AM
I recently had to replace the camshaft sensor. Da** expensive by the way but relatively easy DIY.
#4 frag
frag
    Soob shade tree mechanic
  • 1,777 posts
  • Montréal, Québec, Can.
Posted 05 March 2004 - 09:24 AM
1) It's one of the most simple part to replace. ONe connector and one bolt.
2) Price: if your car is 95-03, you're in luck crank and cam sensors are $17.96 USD each at 1stSubaruParts. If earlier, you're out of luck, it's $183.00 for the crank sensor.
In Canada they ask the same high price even for the 95 and after models. Go figure...
https://www.1stsubaruparts.com/
#5 applegump
applegump
  • 316 posts
  • CH
Posted 05 March 2004 - 04:44 PM
Sounds about right, I was definately out of luck!
#6 avk
avk
  • 965 posts
Posted 05 March 2004 - 05:21 PM
Never knew that pre-1995 sensors cost 10 times more. What can possibly explain such difference?
#7 Hank Roberts
Hank Roberts
  • 342 posts
Posted 14 June 2005 - 12:58 PM
answering a year old question -- on the older cars the 'crank angle sensor' is part of the distributor and can't be fixed except by replacing the distributor.
Thus per the service bulletin files I got from Alldata for the 1988 GL, anyhow. I don't know when it changed to being a separate component instead of built inside the distributor.
#8 TheBigJ
TheBigJ
    USMB Regular
  • PipPipPip
  • 53 posts
  • Seattle WA
Posted 15 June 2005 - 12:50 AM
My 90 Legacy has the sensor mounted in the oil pump housing, comes right out with one screw. Based on what you say I would guess they started doing this with the EJ22 engine. I can't explain the high cost (nor did I confirm it).
For you electronics guys - is this a hall effect sensor? I don't know what else it could be...
