gvh Posted March 10, 2004 Share Posted March 10, 2004 Picked up an 84 with an automatic transmission. Not what I would like but I want to run it until I can swap to manual. Did an atf and gear oil change but it still has an issue and I wonder if this is something that can be adjusted. At low rev the car pulls like the trans is too engaged. My idle is fine. This is most pronounced in Reverse. In all cases Drive, Reverse and even Neutral to a degree the effect is has a kind of wonky feel to it and shakes the car a bit. Idle Reverse is the most wonky. Once I rev up and head down the road in any gear she seems sweet. Any ideas? Thanks in advance. Greg Quote Link to comment Share on other sites More sharing options...
Qman Posted March 10, 2004 Share Posted March 10, 2004 How long did the car sit for? How many miles on the trans? You could be experiencing the first effects of the governor going south. The autos eat governor shafts when the diffs begin to where out. Here's a link from the USRM(Ultimate Subaru Repair Manual) Governor repair Quote Link to comment Share on other sites More sharing options...
gvh Posted March 12, 2004 Author Share Posted March 12, 2004 Thanks Qman, It hasn't sat much as far as I can tell. 150k on the trans. Thanks for the link. I pulled the governor and it felt "smooth as a knife through butter" with little to no "applecore". Swapped and adjusted the shifter assembly. I guess the problem is deep inside. Thanks again for the help. Greg Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 12, 2004 Share Posted March 12, 2004 Watch those autos - really crappy they are. I know of at least 3 that have torn themselves apart under 200k. GD Quote Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted March 12, 2004 Share Posted March 12, 2004 sorry to butt in on thread. General your e-mail is full,tried to pm but could do it. But to inquire about a/t's how hard to swap to manual? Quote Link to comment Share on other sites More sharing options...
gvh Posted March 12, 2004 Author Share Posted March 12, 2004 Yes that may be on my list of things to do. I figure I run it and hope she holds till I get the time. Is there a year issue on that or can I plug in any manual trans from an e81? Personally, I want to keep this thing as stock as possible. I roughly understand the mechanical on a manual, pedal cage... but is there any electrical or dash readout issue. Do the plugs exist for the high/low to show in the dash and does the dash have the bulbs? gvh Quote Link to comment Share on other sites More sharing options...
