Dohc Ej22???
  • This topic is locked This topic is locked
39 replies to this topic
#1 GLCraig
GLCraig
    Livin' the live
  • 2,706 posts
  • LV, Washington
Posted 21 March 2004 - 03:17 AM
I know that DOHC was not available on the EJ22 in North America but I was wondering if they came on EJ22s in some other markets. I'm having some delusions of grandeur(sp) and DOHC would be a nice thing to add to this.
#2 DerFahrer
DerFahrer
    Formerly subyluvr2212
  • 2,420 posts
  • Orlando, FL
Posted 21 March 2004 - 01:39 PM
The only DOHC EJ22 was the EJ22T that was in the VERY limited-production (400) 22B in Japan and a handful in Europe.
Except for that car, the US was the only market to receive the EJ22 at all, I'm pretty sure.
If you are having aspirations of a DOHC EJ22, try this: Find an EJ22T, the best Subaru engine ever IMO, and find a way to get a set of AVCS DOHC EJ257 heads off the STi/Forester-T/Baja-T. Those heads will fit an EJ22T, and then you have a Subaru engine with forged bottom end and an unquestionable reputation, with variable valve timing, DOHC, sodium-filled valves, etc. etc. Talk about an engine! :brow:
#3 blitz
blitz
    Banned
  • Banned
  • 1,091 posts
  • Warren, Michigan
Posted 21 March 2004 - 05:19 PM
Then... while your at it, throw in a 2.5 crank and wind up with 2.4 liters (almost a 2.457, minus the thin walking bores). :drunk:
#4 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 21 March 2004 - 10:34 PM
I think the correct engine designation is EJ22G, not EJ22T.
#5 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 22 March 2004 - 10:31 AM
EJ22 was available in Europe and most of Asia
#6 cookie
cookie
  • 3,058 posts
  • SFO
Posted 22 March 2004 - 12:27 PM
this unless someone has done it before and you can get all the specs.
I have done a number of head swaps, mostly Chevy and Ford, and even when you have a pretty good idea of results unexpected things crop up.
#7 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 14 October 2004 - 08:53 PM
you can hybrid an EJ22x into DOHC...search NASIOC for it...and there were only 424 Impreza 22B STi's with the EJ22G DOHC engine in it....
Easy to do...mix and match heads and head gaskets...and voila! 2.2 DOHC...either turbo or NA...most do the EJ22G USDM legacy block and WRX/RS DOHC/STi AVCS heads for big time turbo HP.
#8 JonOfScio
JonOfScio
    OMGZ!!! HATCH ATTACK!
  • 713 posts
  • Corvallis, OR
Posted 14 October 2004 - 10:15 PM
and of course now, the EJ18 comes into the subject.
Anybody know if all or some were semi-closed deck? The EJ18 is a good candidate for a low expense turbo engine, minus the one downside from it being the pistons. cast pistons with forged crank and rods? meh. but - it's got more meat to the cylinders than the EJ22E, and we know that people turbo those (with 2.2T internals, 14psi has been done.) So I think a properly built EJ18 with good pistons could push some serious power. heck the EJ257 is semi closed deck and it does just fine.
#9 DerFahrer
DerFahrer
  • 2,420 posts
  • Orlando, FL
Posted 15 October 2004 - 12:05 AM
We over on LCo have a member who put DOHC EJ20 heads on a new EJ22T block and put it in his 99 OBS. Car hauls, and not surprisingly sounds more like an EJ20 than an EJ22...
There's nothing wrong with an EJ18 either. Two EJ18 Imprezas are turbo'ed here locally, I haven't seen anything of the FWD auto 4-door Impreza that the guy put a turbo on, maybe he blew it up. But a Subaru tech at my local dealer has a 96 Impreza Brighton coupe with a turbo'ed EJ18. Car is a monster, it's only held back by its less-than-skillful driver :rolleyes:
#10 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 15 October 2004 - 06:48 AM
Right idea, wrong heads. The heads you mentioned here are for open or semi-open deck engines, since all the USDM EJ22Gs I've seen were closed deck, you'll need to get a set of closed deck heads, those came on the early EJ20G used in the Legacys (JDM and others)
#11 THAWA
THAWA
    Eat, Live, Breath Subaru
  • 348 posts
  • Sac
Posted 15 October 2004 - 10:28 AM
Corky-why would you need spefic heads for a specific engine, they all match up, the only difference is the coolant passages, and so far noone has had anything detrimental happen from that.
Jon-I believe all of the Phase I engines had cast pistons and forged crank/rods (maybe not the sti engines) so I don't think it's that big of a deal
#12 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 15 October 2004 - 11:09 AM
Yeah...i thought that the only thing you had to match up properly was the headgasket to the proper HEAD and BORE of the block.
#13 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 15 October 2004 - 01:20 PM
Well, would you rather be safe or sorry. I also visit NASIOC board alot, that this subject has been talked almost to death there. I believe the concenus is that you need to match the heads to the engine. It is not just the coolant passages that need to line up, there are oil passages there also. Do you want oil in the water and water in the oil? I would feel much safer knowing the all the passages line up like they should.
#14 JonOfScio
JonOfScio
  • 713 posts
  • Corvallis, OR
Posted 15 October 2004 - 01:30 PM
oooh yeah, forgot about all of that. open deck and closed deck stuff.
So there has been one confirmed EJ18E with Ej20G heads that didn't have oil/water issues.
I thought the EJ22 had all forged internals (including pistons) but I may be wrong.
#15 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 15 October 2004 - 02:33 PM
The EJ22G does.
#16 THAWA
THAWA
  • 348 posts
  • Sac
Posted 15 October 2004 - 09:36 PM
but the EJ22T does not.
has someone had a problem with oil and coolant mixing?
#17 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 October 2004 - 07:42 AM
The EJ22 TURBO is the EJ22G.
#18 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 16 October 2004 - 10:23 AM
I guess I should ask (should have asked before), what year EJ22 do you want to put these heads on? I know that the early ones (89-94) are closed deck, which also covers the turbocharged EJ22G, for those engines you would need a closed deck head from an EJ20G (or the JDM N/A EJ20, also DOHC). I know in the newer cars the EJ22 was changed slightly, but I don't know what the decking is in those engines. The best thing is to match the engine deck to heads from and engine with like decking (closed, semi-closed, or open). The engine I will be putting together is an EJ22G out of a Turbo Legacy, I have the heads off of an EJ20G. It may be awhile before this comes together, but when I'm done, I should have something close to a 22B engine.
#19 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 October 2004 - 10:55 AM
So the NA EJ22E (i think its 'E') from the legacy 90-94 is closed deck? Ive got one of those engines sitting here...I should take the heads off...i dont recall seeing any grid pattern on the block....
edit: dont take that as a smart-***** remark, I just remember reading the NA EJ22's are all open deck.
#20 THAWA
THAWA
  • 348 posts
  • Sac
Posted 16 October 2004 - 12:56 PM
No, it's an EJ22T
Read here: http://bbs.legacycen...ght=ej22t#83599
Here's a post explaining the difference between the EJ22G and the EJ22T: http://bbs.legacycen...p?p=85027#85027
Or find a 91-94 legacy turbo and look at the engine code on the placard on the strut tower.
#21 THAWA
THAWA
  • 348 posts
  • Sac
Posted 16 October 2004 - 12:58 PM
there are no 89-90 legacy turbos, or even 89 legacy's for that matter
I'll ask again though has anyone had any actual problems with oil and coolant mixing? I seriously want to know this, not trying to be a wongleflute.
#22 THAWA
THAWA
  • 348 posts
  • Sac
Posted 16 October 2004 - 12:59 PM
no it's not. There aren't any NA Closed deck EJ-series engine. Factory anyway.
#23 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 October 2004 - 01:04 PM
Thats what I thought.
the EJ22 T vs G makes sense now, thanks for the links.
Altough...i do remember reading something about a FACTORY 155 or so HP EJ20 that was closed deck...Marnix has one in his Legacy over in Europe.
#24 WJM
WJM
    SUBARU
  • 7,828 posts
Posted 16 October 2004 - 01:07 PM
Yes, there were legacys in 89...thats when they came out. AND..there were turbos...the RS over seas and the RS here...EJ20x and EJ22T...we never got the EJ20x version tho. There was even an STi Legacy in tohse days as well.
Ive not read into detail the problems of a hybrid EJxx setup so I dont know the A...
#25 THAWA
THAWA
  • 348 posts
  • Sac
Posted 16 October 2004 - 01:10 PM
that's quite possible, I should've said I'd never heard of any :)
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
