'91 Legacy - Stumble During Hard Turn?
8 replies to this topic
#1 uwjberg
uwjberg
    New User
  • PipPip
  • 27 posts
  • Bothell, WA
Posted 19 February 2012 - 10:09 PM
Hi all - just picked up a '91 Legacy wagon. When we made a hard right turn to go up a hill today testing the new tie rod ends, the motor stumbled and nearly cut out before catching again. It was a pretty hard turn, I admit. Seems to run fine any other time. My first thought was fuel starvation, but it has 1/4 tank of gas. Any ideas? Where should I look first?
#2 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 19 February 2012 - 10:28 PM
I've had the same thing happen with mine a few times, but it's only when I have about a gallon and a half of fuel left in the tank. The fuel pressure pump is on the right side of the tank, so going fast around a hard right turn pushes all the fuel over the hump in the middle and over to the left side of the tank, then it takes a few seconds for it to flow back.
Go fill it up, see how much it takes (it's a 15.9 gallon tank) then go try the same corner again and see if it still does it.
#3 brus brother
brus brother
    Subaru Master
  • 2,226 posts
  • Connecticut
Posted 20 February 2012 - 09:28 AM
http://www.ultimates...rn smoke loyale
Check out post #2 by General Disorder.
This uphill right turn stumbling related to PCV may be your issue.
Edited by brus brother, 20 February 2012 - 09:36 AM.
#4 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,923 posts
  • Portland
Posted 20 February 2012 - 01:36 PM
Last time I had that problem on a Legacy it was because the pickup tube that was supposed to be on the bottom of the fuel pump was missing due to some hack replacing the fuel pump and leaving it out. It's a short tube attached to a mesh bag that keeps rocks, birds, and small children out of the pump.
#5 Ricearu
Ricearu
    Official De-Ricer!
  • 1,214 posts
  • DFW, TX
Posted 21 February 2012 - 02:58 AM
the mesh bag he speaks of (some call it the sock) has fallen off. mine did exactly that. Pissed me off when I was driving "spiritedly" through the cloverleaf on my WRX struts/springs and my car would cut an buck and surge. ;)
#6 uwjberg
uwjberg
    New User
  • PipPip
  • 27 posts
  • Bothell, WA
Posted 21 February 2012 - 09:09 AM
Thanks for all the ideas. I assume that the mesh bag is a pain to get to since you have to drop the tank to get to the pump?
#7 Frank B
Frank B
    Subaru Master
  • 2,226 posts
  • VA
Posted 21 February 2012 - 10:28 AM
There should be an access cover under the carpet. Under the back seat.
#8 GeneralDisorder
GeneralDisorder
  • 21,923 posts
  • Portland
Posted 21 February 2012 - 11:16 AM
Not at all - just pull the access cover in the trunk area.
#9 uwjberg
uwjberg
    New User
  • PipPip
  • 27 posts
  • Bothell, WA
Posted 21 February 2012 - 11:29 PM
Awesome - thsat will be MUCH easier. Thanks!
