Axle question.
18 replies to this topic
#1 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 13 March 2012 - 06:23 PM
So I have re-booted many an axle but this is my first time with an axle that is clicking badly. So do I need to replace the axle or are their new bearings/joints available? Whats the best solution? Just want it to be as reliable as possible.
#2 Ionlyhave3suubs
Ionlyhave3suubs
    USMB is life!
  • 201 posts
  • Virginia
Posted 13 March 2012 - 07:58 PM
If it were mine, I would just replace the axle. Once they start clicking to me they aren't worth trying to salvage when you can get aftermarket and rebuilt units as cheap as you can.
#3 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 13 March 2012 - 09:21 PM
Is it ok to go with the ones on ebay or where can I find them? Want the best quality ones possible, not too worried about the price.
#4 1 Lucky Texan
1 Lucky Texan
    I read a lot about Subarus. '03H6OBW,'06WRX
  • 7,956 posts
  • Texas
Posted 13 March 2012 - 11:14 PM
EMPI from RockAuto or Amazon(they are new and properly case hardened.)
MWE is a well respected rebuilder of Subaru axles.
maybe Raxles
Supposedly, rebuilts from the dealer are good.
Everyone seems to agree the worst are from parts retailers like A'Zone, O'reilly, etc.
you can start some arguments with this question, like engine oil discussions.
You can reboot them yourself - but it sounds like you need more than just a boot on one of yours. Somefolks will swap sides so the force is on 'almost' new surfaces.
Personally, I have an EMPI on the wife's Outback. Zero problems so far. (do not torque with the wheel on the ground)
#5 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 15 March 2012 - 03:25 PM
Anyone have an idea where to pick up rear axles? Found that all of those companies and ebay are selling the same axle (Cardone Industries), anyone used them?
#6 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 15 March 2012 - 04:05 PM
Well from what ive read the Cardone axles are the same ones that Oreilly and Autozone sell under a different lable. Unless I can find some better ones somewhere I will probably just pick them up from Oreilly's since they have a lifetime warranty I can just swap them out if I have issues. Don't plan on lifting the brat or doing anything crazy so shouldn't be under extra strain. Still can't find rear axles anywhere though.
#7 talldude
talldude
    USMB Regular
  • 163 posts
  • Placerville
Posted 15 March 2012 - 09:20 PM
A dealer or wrecking yard oem axle or joint might be your best bet, long term. As far as boots, I have not ever gotten longer than 2 years out of non-oem rubber, especially the rh inner (over the exhaust). Good luck.
#8 1 Lucky Texan
1 Lucky Texan
  • 7,956 posts
  • Texas
Posted 15 March 2012 - 11:04 PM
contact MWE ; Phone: (303) 522-8070 Fax: (303) 695-4984
If they can't help, reboot and swap sides with yours, or get junkyard axles, reboot/regrease and swap sides.
Cardone might work for you, but it's the most risky option from what I've read.
#9 1 Lucky Texan
1 Lucky Texan
  • 7,956 posts
  • Texas
Posted 29 March 2012 - 01:09 PM
what did you go with?
did it work out OK?
#10 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 29 March 2012 - 07:43 PM
Haven't messed with it yet, been focusing on getting the electrical issues and the heater assembly sorted out first. thinking I might just buy all new boots and try swapping all of the joints around as suggested. Anyone suggest a good place to buy new boots (links or part numbers would be nice :))
#11 talldude
talldude
    USMB Regular
  • 163 posts
  • Placerville
Posted 29 March 2012 - 08:16 PM
Again, I would buy only oem Subaru boots, likely from your LD. They're not expensive. Use zip ties or safety wire to secure the ends and buy the CV grease in a tube from NAPA. Take the joint completely apart to clean and inspect. Not difficult and not worth doing it any other way IMHO, unless you feel your time is cheap and you'd like the practice of doing it again in a year or 2.
#12 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 29 March 2012 - 08:57 PM
Yeah its texas....we don't really have subaru dealers, I think the nearest one is over an hour and a half away. Don't sell OEM quality ones online anywhere?
#13 Ionlyhave3suubs
Ionlyhave3suubs
    USMB is life!
  • 201 posts
  • Virginia
Posted 29 March 2012 - 09:02 PM
http://1stsubaruparts.com/
#14 raging squirrel
raging squirrel
    USMB Regular
  • PipPipPip
  • 35 posts
  • Hudson
Posted 31 March 2012 - 10:11 PM
A note on CV boots: be sure to apply plenty of grease inside of the lobes(grooves) or premature wear/failure may result. Don't assume that the grease will fling out from the joint and take care of it automatically. This applies to any CV boot, even ATV's.
#15 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 10 April 2012 - 06:59 AM
Looked on 1stsubaruparts and saw a few different things and wasn't sure which ones I actually need. I have heard that you can just get one CV boot that will work in all 8 spots...can someone direct me to which one I need to buy? (plan on getting at least 8 and going ahead and replacing all of the boots at once.) Or am I wrong and I need to get different ones for each spot?
#16 SUBARU3
SUBARU3
    Moderator
  • Moderator
  • 2,842 posts
  • Dallas, Ft. Worth, Texas
Posted 11 April 2012 - 06:40 PM
Contact Front wheel drive supply in Hurst TX. I have had MANY, MANY axles, hubs and driveshafts serviced there. They are great , fast and reasonable.
Front Wheel Drive Supply
808 W Hurst Blvd, Hurst, Texas76053
Name: Front Wheel Drive Supply
Street: 808 West Hurst Boulevard
Hurst, tx 76053-7502
Phone: (817) 284-8187
#17 1 Lucky Texan
1 Lucky Texan
  • 7,956 posts
  • Texas
Posted 11 April 2012 - 11:00 PM
I have no experience with doing this (well, a very long time ago, I tried a split boot on a Honda - didn't las a month)
BUT, maybe you'remebering this;http://www.ultimates...ad.php?t=118248
also, if you do decide to go with a local rebuilder - MANY people (including me) have successfully used DAPE in north Fort Worth. (around 33rd street I think. )
#18 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 12 April 2012 - 04:37 PM
Anyone know if all of the axles are the same? Every place I have called said they are getting the same part number for all of the axles. Anyone know for sure? Trying to get the parts coming tonight or tomorrow before I go out of town for the weekend and wont have time to take them off and measure and check them out before I go. And yes, that was a write-up I had read about the boots and such thanks.
Edited by BlindSight, 12 April 2012 - 06:12 PM.
#19 BlindSight
BlindSight
    Subaru Nut
  • 653 posts
  • Denton
Posted 13 April 2012 - 05:23 PM
Nevermind, had a death in the family so stayed in town and was able to get the axle off and it is clearly different. The boots do all look to be the same though. Going to go ahead and order one new axle and rebuild the other 3.
It has begun...
Posted Image
Edited by BlindSight, 13 April 2012 - 07:38 PM.
