Whitch clutch?
What clutch should I get and where should I get it? I have a 88 gl 5sp D/R and would like to get the best one I can get. Can I use the one for the H6 or does some one offer a Heavy Duty clutch kit?
Earl
I'm looking into the XT6 clutch for an EA82T question myself, for Garner's mondo Brat build. Am going to compare the two discs for myself tomorrow when they get here from my warehouse. Pressure plate, throwout bearing and pilot bearing are exactly the same according to the book. I'll let you know what I see tomorrow.
The disc for the XT6 has 6 springs instead of the 4 dual spring packs the EA82 disc has. The spring pack on the XT6 disc sits closer to the friction, as well. Finally, the XT6 disc itself is mounted a little bit closer to the bottom when you have both of them sitting on a flat surface. No apparant benefit in using the XT6 disc, and probably some actuation issues.
