What size winch to buy?
3 replies to this topic
#1 stinkydogfilms
stinkydogfilms
    USMB Regular
  • PipPipPip
  • 56 posts
  • houston texas
Posted 08 November 2012 - 06:06 PM
I want to buy a winch for the 86 Brat. What size capacity winch should I buy?
Will a 2000 lb capacity winch do the job?
Thank you Mike
#2 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,508 posts
  • Puyallup
Posted 08 November 2012 - 07:24 PM
Generally a 2K winch isn't enough. Yes, you can double line it to get 4K, but your distance is shortened and time to pull increased. 4K-6K is what I'd go with. The pull also depends on how stuck you get, incline, etc. The more stuck you are, the more power required. I have an 8K Ramsey planetary for my 3/4 ton Chev. Can't have one too big! lol
#3 El Presidente
El Presidente
    Subaru Fanatic!
  • 621 posts
  • Northgate/Seattle, WA
Posted 08 November 2012 - 07:30 PM
2000lb. is gonna be small, even on a brat for serious wheeling. Rule of thumb on a winch is to go twice the vehicle weight, so a 4-5K winch is a minimun. I think super winch sells a 4500lb. winch for sidexsides, which I've heard good things. I'm going straight to a 8K warn eventually, because I know if I get a 4.5K, I'll wish I had a 8K.
Some people have run 2k winches just fine too..just depends on what your doing..
Josh
#4 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
the 2000lbs Ive seen are junk get something bigger, they have a 4500-500 ATV winch that should do, I have one on a small boom I use and like it, got it on ebay
