Body trim Glue?
5 replies to this topic
#1 Flow
Flow
    Eat, Live, Breath Subaru
  • 257 posts
  • Roy
Posted 16 April 2004 - 11:11 PM
What's the best stuff to use to reattach the black plastic body trim on my '86 wagon? Thanks.
#2 Subi81
Subi81
    1000+ Super USER!
  • Gold Subscribers
  • 1,006 posts
  • Ventura, Ca
Posted 16 April 2004 - 11:37 PM
Just did that same thing on my 86 turbo wagon, I got my stuff from Franklin auto parts, I think they are just a local shop here is what I used.
3M weatherstriping adhesive (black) part No. 08011
Here is a link to 3m site and speil on the stuff
http://products3.3m....ler/output_html
Just lathered it on the door and the trim let it set up for 5 min, then pushed on the strip.
Whatever you do don't use Hot Glue, 1 day in a 100 deg day and it will be lieing on the ground faster then you can say, Dammmit!
Good luck!
#3 samo
samo
    Boo.
  • 731 posts
  • The Emerald City
Posted 17 April 2004 - 01:03 AM
My sidemoldings are attached with clips, but what I would generally use is 3M double-sided foam tape, AKA doublestick. I'm sure you've seen it - grey foam tape with a red plastic backing that's really hard to get off? I use that stuff for everything.
#4 Dr. RX
Dr. RX
    Elite Master of the Subaru
  • 9,984 posts
  • Sammamish, WA
Posted 17 April 2004 - 10:34 AM
I use the same glue that they use to iinstall windsheilds. but be careful not to put too much on, it will ooze past the edges and look terrible.
#5 soobme
soobme
    Subaru Master
  • 1,871 posts
  • Medford OR
Posted 17 April 2004 - 01:19 PM
I use 3M "Automotive Trim Adhesive", comes in an arisoll can, its yellow when it comes out and it works GREAT! I think its a varieant of permatex, AKA: The yellow deth.
#6 draggon
draggon
    USMB Regular
  • PipPipPip
  • 82 posts
  • Anna
Posted 18 April 2004 - 01:31 AM
you might want to try something called GorillaGlue its really strong and garunteed to last,you can go to ( www.gorillaglue.com) to check for a store near you that sells it
david
