Legacy clutch and timing belt, need help
2001 legacy clutch timing belt help
4 replies to this topic
#1 luko
luko
    Advanced Member
  • PipPipPip
  • 121 posts
  • Wayne, NY AKA Upstate NY
Posted 10 June 2013 - 10:00 PM
What I have is a 2001 legacy sedan and what I need is a good clutch and timing belt kit. My car has 113xxx on her and the clutch is on her way out and while I have the engine out I want to do the timing belt and everything because it was last done at 50,000 so I figured on just doing everything at once so I don't have to worry about it for another 100,000 miles.
        But what I want to find out is what is a good clutch but nothing to expensive, also what is a good timing belt kit
    Thanks, Luke
#2 Prwa101
Prwa101
    Subaru Fanatic!
  • 832 posts
  • Sandy, OR
Posted 10 June 2013 - 11:33 PM
Exedy, http://www.amazon.co...&sr=8-1&pi=SL75
And Gates makes a good timing kit. Replace it all though if your going to do it, hate to see you down the road in 20k with a blown idler bearing or smacking tensioner.
Double cheap my search with your exact make and model.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,973 posts
  • Charlottesburg, VA
Posted 11 June 2013 - 08:43 AM
+1 Exedy. Exedy Daikin makes the factory original clutch.
Gates makes a good timing belt kit, though they're usually a bit pricey.
Look for The Import Experts on eBay, or you can go to their website. They sell timing kits with everything you need at competitive prices.
Be sure to replace everything while you have it apart, belt, all of the idlers, tensioner, water pump, replace the front crank and camshaft oil seals, and the o-ring behind the oil pump. You should also check the screws on the backing plate of the oil pump to make sure they are tight.
When reassembling be sure to get the crank pulley bolt VERY tight, about 140 ftlbs, otherwise it could loosen and cause damage to the end of the crank.
#4 luko
luko
    Advanced Member
  • PipPipPip
  • 121 posts
Posted 11 June 2013 - 06:18 PM
Okay, Thanks for your input!
#5 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,753 posts
  • East Coast
Posted 17 June 2013 - 07:17 AM
Import Experts on Ebay - they have the best prices on decent quality.  some of the cheaper kits on ebay seem less robust, having installed multiple sets from various suppliers.
They will also allow you to contact them and add or take out any parts you want and essentially create your own kit.
While you're in there around the timing belt, for a reliable 100,000 miles you'll want to:
replace timing belt, pulleys, and tensioner
reseal the oil pump (one oring from Subaru and anaerobic or appropriate RTV sealant around the pump case)
replace crank seal and 2 cam seals
replace the water pump - use a Subaru water pump gasket - the aftermarkets are cheap cardboard junk and prone to leak
replace the thermostat - use Subaru or XACTA from Stant, the others are visually inferior.
If it has a plastic rear separator plate you'll want to replace that and probably reseal the existing one if it's metal.  They crack/leak and it's easily done with the engine out for a clutch job.
Rear main seal issues in Subaru's are nearly bullet proof and never leak so make your own call on that.  Just be sure to install it exactly right and use a Subaru or Subaru quality seal - they are less forgiving than any other seal on unclean installs.
Also tagged with one or more of these keywords: 2001, legacy, clutch, timing belt, help
