Hooking up a power amp
stereo
10 replies to this topic
#1 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 20 June 2013 - 10:08 AM
I am going to put an old clarion 4 X 50 watt in my car.
1. What guage wire to use for the battery and ground wires.?
2. Do you hook the battery wire up directly to the battery, or do you find an existing hot wire?
3. What guage speaker wire is adequate?
#2 92loyale59
92loyale59
    Eat, Live, Breath Subaru
  • 271 posts
  • clackamas
Posted 20 June 2013 - 11:22 AM
i usually use 8 gauge wire for the power and the ground for lower watt systems and i run the power directly to the battery . put a inline fuse on the power wire within a foot or so of the battery. if you wondering what sized wire to run the speakers of off im pretty sure you wont find a huge difference no matter what size. i always use 12 gauge speaker wire but since thats not that power full of a amp it wont matter much. make sure when you run the wires inside the car to run the power down one side and th RCA cables and remote wire down the other.
#3 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 20 June 2013 - 11:42 AM
Thanks for the response. Do you run the wires down opposite sides to avoid getting a buzz?
#4 rdweninger
rdweninger
    USMB Regular Nut
  • 785 posts
  • Tillamook, OR
Posted 20 June 2013 - 01:56 PM
How many amps will your amp draw?   Then we can size the proper wire and fuse.  Fuse is important.
I remember putting a 30 amp fuse in my big fat hot wire back in high school.   Don't remember the gauge... probably 6.
Then my little brother shorted the wire out (at the fuse junction) with an empty beer can.  Guess why?
#5 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 20 June 2013 - 03:30 PM
How can i figure out Amp draw? It's a clarion A2000, also may go by EE-1009-AA, It was made in 1993 and I don't have a manual and can not find it on-line.
#6 AKghandi
AKghandi
    87 GL-10
  • 1,197 posts
  • Somewhere, Someplace
Posted 20 June 2013 - 05:00 PM
one thing to consider, is how much power our stock alternators make..not alot. you can power it but your head lights light dim with the beat.
#7 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 20 June 2013 - 07:15 PM
For a 1,000 watt sony xplod amp I installed I used 2 gauge wire for the hot and the ground. I used 10 gauge speaker wire. Run the power on the opposite side of the car than any other wires. 60 amp fuse at the battery.
#8 92_rugby_subie
92_rugby_subie
    Subaru Master
  • 1,995 posts
  • Hillsboro OR
Posted 20 June 2013 - 09:20 PM
For the alternator, look up the Maxima alternator upgrade... 90amp unit over the 50/55 amp one that comes stock in these cars
#9 the sucker king
the sucker king
    great fisherman
  • 1,991 posts
  • Lyons, Colorado
Posted 22 June 2013 - 09:13 PM
Two people have said run the power down opposite sides of the car. Is this so there is no buzz? Also does anybody know how I can determine amperage draw? Assuming I can't determine this, I will get the thickest wire i can find (2 gage?) for the ground and power, And what should I put in for a fuse? Again it is a 4 X 50 watt amp. Thanks.
#10 Mykeys Toy
Mykeys Toy
    Subaru Master
  • 2,089 posts
  • South Prairie, Wa
Posted 23 June 2013 - 03:29 PM
Not for that small of an amp.. Honestly for a 200 watt RMS amp I would be surprised if it drew more than 30 amps at full throttle using 10 awg.  If you are going to run more or bigger amps in the future I suggest using a 4 awg amp kit.. Bigger wire = less amp draw on the electrical system.  Something else you might consider is the " big 3 " wiring upgrade it will help minimize your light dimming which would be almost non existent with your amp anyway.  I have done all this in my brat pushing somewhere around 600 watts continuous at one point and never had dimming issues.
  Anyway back on topic  I do try to use the bigger is better method with car stereo wiring.. Not overkill by any means so maybe 8 awg would work if you are not going to upgrade later.  As for speaker wire I never use less than 12 AWG but beware the 12 gauge stuff at many stores is more like 14 .. Shop around a bit amazon, partsexpress or a car audio shop local to you.
 Running your power wires I run them down the same side as the battery under the carpet and down the trim.  RCAs and speaker wire down the opposite side.  The important thing for humm or alt whine is to make sure your grounds are good.. From the deck and also with the amp.. That is where 75% of noise is introduced.  Fusing your amp as long as your using appropriate power wire 200 watts divided by 13 volts ( car running) = 15.4 amps if my equation is right so you should be able to run a 25 amp fuse.
 For more info try this http://www.the12volt...~TID~73496~PN~1
#11 91 subaru
91 subaru
    USMB is life!
  • 247 posts
  • miami, ok
Posted 23 June 2013 - 03:50 PM
Suckerking, do you still have the parts for sale that we were talkin about?
Also tagged with one or more of these keywords: stereo
