4" lift PStearing pulley in the way?
2 replies to this topic
#1 SubaSport
SubaSport
    New User
  • PipPip
  • 17 posts
  • Gunnison Colorado
Posted 19 April 2004 - 10:46 AM
I am starting my 4" lift on 82 wagon. Ive been looking at how it all will work and I am worried about my power stearing pulley, it looks like it will hit radiator fan. Is this a common problem? If this helps, I attempted to to put in a block heater in the freeze plug but the heater stuck out to far and got in the way of the fan.
Does this sound like a problem? is it a problem? Any info would be awesome
#2 mcbrat
mcbrat
    Brattitude Adjustment
  • Administrator
  • 11,185 posts
  • Central Iowa
Posted 19 April 2004 - 10:52 AM
if your motor is tilting like that then you need to also "lift" the rest of the mounts. you will need blocks at the 6 bolts that hold the radius rod plates/tranny crossmember in place to lower the back side of the motor trans combo. the entire drivelines should just drop straight down as the body is lifted up.....
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,722 posts
  • Portland
Posted 19 April 2004 - 11:37 AM
I have power steering on my lifted wagon. 3.5" lift in the front. The pulley is nowhere near the radiator fan.....
