EJ25D 2.5 DOHC - Advice for timing belt kit w/ water pump, idlers, tensioner
EJ25 EJ25D timing water pump timing belt timing belt tensioner DOHC Legacy
3 replies to this topic
#1 kevinrse
kevinrse
    Advanced Member
  • PipPipPip
  • 37 posts
  • Blacksburg, Virginia
Posted 15 April 2014 - 01:12 AM
I posted earlier tonight about a recent cylinder misfire. In that thread, Fairtax4me suggested that I make sure my timing belt hasn't slipped. But even if the timing belt isn't the source of my current engine dilemma, I figure I should make that my next DIY project. Supposing I want to order a complete timing belt component kit, including idlers, tensioner, and a water pump---can anyone offer advice on where to go for quality components?
My car is a '99 Legacy Outback 2.5L with 230,000 miles. I have found components kits on RockAuto.com and eBay ranging in price from $150 to almost $400. I understand OEM quality components are desirable, but I don't know who the OEM manufacturer(s) are. Also, I wonder if it's overkill for me to worry about OEM with an older car. I don't know about the reputations of the various aftermarket manufacturers. Can you suggest a reasonable plan of attack, brands you trust, or a preferred online vendor?
Thanks!
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 23,745 posts
  • East Coast
Posted 15 April 2014 - 03:36 AM
I'd find out what your cylinder misfire is before dumping money into timing belt.
If it's a burnt exhaust valve, are you going to repair it?
Yes, OEM is overkill and over priced. Gates kits from Amazon or Rockauto for like $125.
Water pump gasket and thermostat should be Subaru only, the aftermarkets are visibly and notable whimpy.
#3 tbolt1003
tbolt1003
    USMB is life!
  • 200 posts
  • Media, PA
Posted 15 April 2014 - 06:30 AM
I did the RockAuto kit for my '95 Impreza and it is working fine.
#4 kevinrse
kevinrse
    Advanced Member
  • PipPipPip
  • 37 posts
Posted 15 April 2014 - 10:20 AM
@grossgary, yeah you're right, I do want to wait for diagnosis before purchasing. A friend has compression test equipment, so hopefully can get a better idea what's going on tonight or tomorrow. I got more hopeful that it wasn't burned valves based on Fairtax4me's comments---we'll see though...
Glad to know that the priciest timing kit isn't necessarily needed.
