1987 fuel problem or is it electric
help
7 replies to this topic
#1 stillmarykay
stillmarykay
    Newbie
  • Pip
  • 4 posts
  • Upton, Wy
Posted 16 June 2014 - 04:29 PM
1987 Subaru gl  we have gone through the fuel system, new pump, new filters, rebuilt carb.   It just won't keep running, like its not getting enough fuel.  Won't rev up.  Like its not getting enough gas.  Help
#2 naru
naru
    1000+ Super USER!
  • 2,299 posts
  • under the bridge
Posted 16 June 2014 - 05:41 PM
Check for plugged exhaust.
#3 stillmarykay
stillmarykay
    Newbie
  • Pip
  • 4 posts
  • Upton, Wy
Posted 16 June 2014 - 08:36 PM
Thanks for the idea we checked the exhaust and it is not plugged.  I keep thinking its not fuel, we checked spark and that is all good.  Keep trying open to any and all other suggestions.
#4 skishop69
skishop69
    If it ain't broke, you're not trying.
  • 1,524 posts
  • Puyallup
Posted 16 June 2014 - 09:07 PM
EA82 I assume? Have you checked the timing belt to make sure it hasn't slipped? Timing? Carb'd or FI?  Compression test?
#5 stillmarykay
stillmarykay
    Newbie
  • Pip
  • 4 posts
  • Upton, Wy
Posted 16 June 2014 - 09:42 PM
Thanks, you say EA82 , now this is my son's Subaru we have been unsure if it is a 87 or 88.  His title says 88 but it was built in 12/87.  So how do I tell and what is a EA82?  Thanks so much for any and all help you can give us.
#6 wagonist
wagonist
    User Awaiting Email Confirmation
  • 987 posts
  • Sydney, Australia
Posted 16 June 2014 - 10:22 PM
Have you checked whether the fuel lines are blocked?
#7 two85s
two85s
    New User
  • 258 posts
  • South Western USA
Posted 16 June 2014 - 10:24 PM
I have a 85 gl 4WD dual range wagon.   It has "EA82" large and stamped in the metal of the engine.  It is located in front of the carburator approx in the middle of the engine, behind a plastic "cover plate"on my car.  THe EA82 stamp may be covered with grime, grease, etc.  I had a similar problem to what you are describing and I did many of the "fixes" you have done.  Almost by accident I found my problem was a vacuum line cap to an unused tube had been knocked or fell off.  Once I capped the open tube off....bang the engine came back strong.  There are many very knowledgeable Subaru experts on the USMB. Aaron
#8 skishop69
skishop69
  • 1,524 posts
  • Puyallup
Posted 17 June 2014 - 09:39 AM
EA82 is the engine type. They have plastic timing belt covers on the front of the engine. EA81 engines have no timing belt.
Also tagged with one or more of these keywords: help
