new project
34 replies to this topic
#26 RustyBrat
RustyBrat
    Subaru Nut
  • 749 posts
  • Pocatello Idaho
Posted 18 February 2015 - 09:43 PM
ive always been curious how people manage to do straight axles and a transfer case with these transmissions, since they are primarily fwd
#27 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 19 February 2015 - 02:13 PM
Power normally goes through the front wheels,but when needed power is mechanically coupled to the rear wheels.Just like a normal 4wd system,just in reverse.Thats why you can't use 4wd on dry pavement because there is no differential between front and rear, so any turns will bind up the drivetrain.
In a transfer case setup,the subaru transmission is locked in 4wd.The power goes to a transfercase and it is exactly like a normal 4wd system at point.
Edited by Uberoo, 19 February 2015 - 02:14 PM.
#28 ferp420
ferp420
    im not a typer
  • 1,113 posts
  • hammer town ca.
Posted 19 February 2015 - 03:30 PM
i could be wrong but im pritty shure the brzs are rwd only basicly a toyota trans that mates to the subaru motor im just woundering if it wil bolt up to a ej 2.5d thats already in the car
#29 RustyBrat
RustyBrat
    Subaru Nut
  • 749 posts
  • Pocatello Idaho
Posted 19 February 2015 - 06:26 PM
ive heard a few people toss the idea around of building a rwd subie for drifting and whatnot, and they always seem to decide that the rear drive is not strong enough. so, are they wrong?
#30 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 19 February 2015 - 09:28 PM
Short answer: No, they are not wrong.
Long answer: using a normal subaru transmission not BRZ,in rwd all power must flow through a small set of transfer gears that arn't really designed to have 100% of the torque flowing through them.Same with the rear suspension and axles.
So a rwd subie for RWD shenanigans is fun but it will blow transmissions and rear axles...
#31 Uberoo
Uberoo
    Subaru Wheeler
  • 3,863 posts
  • lewiston,ID
Posted 19 February 2015 - 09:32 PM
As far as using the BRZ transmission with EJ stuff-It might work.The bolt patterns look similar and probally are because its a subaru, but the starter on the BRZ transmission is opposite to an EJ engine.There might be enough room to make it fit but...
#32 Gloyale
Gloyale
    It's a sickness
  • 10,928 posts
  • Corvallis, OR PNW
Posted 20 February 2015 - 01:18 PM
One would need to cut an opening on the drivers side of the bell to mount a Starter in the EJ position.
OR.....
Cut the bell area of the passenger side of the EJ25 to make room for the starter snout.
#33 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 20 February 2015 - 02:53 PM
Just use a normal EJ 5 spd with a solid coupler, instead of a viscous coupler.easy, and cheap.
#34 Vegablade
Vegablade
    Eat, Live, Breath Subaru
  • 548 posts
  • Concrete WA
Posted 20 February 2015 - 05:35 PM
This would be the correct way.  Then just get some plugs for the transmission.
#35 Gloyale
Gloyale
    It's a sickness
  • 10,928 posts
  • Corvallis, OR PNW
Posted 22 February 2015 - 12:26 AM
Still puts the output through the transfer gear.
