HOW TO CORRECTLY DO A HARD ECU RESET ON A FORESTER SF5 MODEL 2000 AUTOMATIC TRANSMISSION
Need to let it idle for about ten minutes at the minimum. It's better to wait until the radiator fans cycle once.
Don't touch the throttle, let the ECU make its own adjustments.
If it stalls just restart the engine and let it idle.
After the fans cycle turn it off and let it cool for about an hour. Then start it and let it idle again for 3-5 minutes. Just long enough for it to come down from the high warm-up idle. Then take it for a drive about 15-30 minutes at varying speeds.
I just always wated 15 minutes then started the car, dealt with a stall, restarted and drove. What is happening with a hard reset is not only your clearing the codes (that only takes a minute) but you have erased everything it has learned about you, from your lead fooded starts to how you like to sneak off to the donut shop when you say your going for a run.
  • Like 1
