Kris79 Posted April 24, 2015 Share Posted April 24, 2015 (edited) Hey guys (gals) I recently replaced my timing belts, tensioners etc. Everything was working fine until a couple weeks ago. The left hand side belt it sliding towards the engine. I replaced a tensioner and realigned the belt a few times and it just jumps back. Any idea's please ? I'm at a loss. Just tried to upload pictures. My files are too large and not sure how to reduce the file size. The timing belt started to cut into the plastic cover behind the cam wheel. It's maybe a 1mm or so over the edge and I don't think it's safe to drive. Edited April 24, 2015 by Kris79 Quote Link to comment Share on other sites More sharing options...
Kris79 Posted April 24, 2015 Author Share Posted April 24, 2015 Here are a few pictures Quote Link to comment Share on other sites More sharing options...
DaveT Posted April 24, 2015 Share Posted April 24, 2015 I had a belt that wanted to track funny like that once. . I flipped it over and it was fine. Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted April 24, 2015 Share Posted April 24, 2015 that was a pain, i still remember mine also, left side was the one that always wanted to come out, what i did was removed the tensioner and hammered it alittle to one way, tested it out by turning the vehicle on and see if it fell off, i overdid it and was rubbing on the engine block, so i hammered it some more the other way and got it, that is for buying a cheap quality tensioner btw, i learned my lesson. Quote Link to comment Share on other sites More sharing options...
Kris79 Posted April 25, 2015 Author Share Posted April 25, 2015 I put the old tensioner back on thinking it might be the problem and it did the same thing leading me to think it isn't the tensioner since it wasn't doing this previously. Which way did you bend it ? Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted April 25, 2015 Share Posted April 25, 2015 I put the old tensioner back on thinking it might be the problem and it did the same thing leading me to think it isn't the tensioner since it wasn't doing this previously. Which way did you bend it ?its been a year since i did this, i honestly don't remember sorry but pay attention to the rotation of the belt to which direction it goes and the rotation of the tensioner and bend it in the way you want it to go, thats what i did. Quote Link to comment Share on other sites More sharing options...
Kris79 Posted April 25, 2015 Author Share Posted April 25, 2015 I'll give it a try since I have an extra one Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 25, 2015 Share Posted April 25, 2015 Make sure you don't have the 2 crank sprockets mixed up. If you put the pass side (outer) on the inside it will make belts run off. 1 Quote Link to comment Share on other sites More sharing options...
Kris79 Posted April 27, 2015 Author Share Posted April 27, 2015 Well I pulled it all apart. Put new belt on and double checked everything and the belt just goes back to where it was. I'm going to just run it like this till it flies off. It's a second car and we can live without it even though it's so much fun. Quote Link to comment Share on other sites More sharing options...
Subasaurus Posted April 27, 2015 Share Posted April 27, 2015 im sorry you couldn't fix your issue. Quote Link to comment Share on other sites More sharing options...
