SUBARU3 Posted March 26, 2017 Share Posted March 26, 2017 Has anyone experienced any under dash leaks on these? I have a mystery. 1995 Impreza....drips from the AC evaporator during rain and mostly when the car is facing uphill. Sometimes a lot if the car is position just right! (AC in not running, so it's not AC evap water). Now facing downhill , no leaks. It appears to drip from the very bottom of the evap case. Could it be entering through the cowl/windshield? Everything else seems dry up under the dash. Leaves clogging something? Thanks for your thoughts! Todd Quote Link to comment Share on other sites More sharing options...
gbhrps Posted March 26, 2017 Share Posted March 26, 2017 SUBARU3, I spent a couple of nights this weekend looking at many YouTube video fixes for sunroof leaks, fixes, and brake rebuilds, and came across one showing the same thing you're complaining about. This was on a 06 outBack, but the same issue may apply to your car. The guy placed a running garden hose just above the windshield on the passenger side, and allowed a water spread of 18 inches wide to flood down the glass and on to the cowl. Water then dripped from the bottom of the heater fan housing. He popped out the plastic plugs of the cowl and discovered that Subaru had placed one of those cowl plugs right over the raised opening of the heater intake to the cabin filter and such. The water was leaking through the plug hole when the plug was installed and dripped right into the intake opening. His fix was to take a plastic bottle that juice came in (one that is longer and wider than the air intake opening, cut one side out of it, and placed it loosely over the air intake opening. When the cowl was again reattached with its plugs, it kept the bottle container in place, but still allowed air to be sucked in from around the bottle's sides and ends, and shunted the water over the top of the air intake to drain away as it should. His after video showed no more water leaking inside. His fix, still allowed the plugs to be pulled if further dismantling was required. Could your setup be the same? Quote Link to comment Share on other sites More sharing options...
Olnick Posted March 26, 2017 Share Posted March 26, 2017 gbhrps--could you provide a link to that video? Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted March 27, 2017 Author Share Posted March 27, 2017 Interesting....I will have to take a closer look into the cowl. Todd Quote Link to comment Share on other sites More sharing options...
gbhrps Posted March 29, 2017 Share Posted March 29, 2017 (edited) Subaru3, There's the link you requested. You'll have to put it into your web browser, as this site won't allow me to post the entire link. Edited March 29, 2017 by gbhrps Quote Link to comment Share on other sites More sharing options...
SUBARU3 Posted October 19, 2018 Author Share Posted October 19, 2018 This is exactly what was happening to my 95 Impreza. The cowl plug/pin was indeed right over the fan intake. The plastic plug deteriorates with age and then leaks. Quote Link to comment Share on other sites More sharing options...
bork Posted October 19, 2018 Share Posted October 19, 2018 Ive been fighting this also on my 99 imprezza L. I hope this is the cure for me also. Quote Link to comment Share on other sites More sharing options...
