chadwick Posted November 10, 2004 Share Posted November 10, 2004 A 1998 subaru outback with a #4 cylinder misfire. Replaced plugs and wires, still running bad,replaced coil pack, still running bad. put fuel injector cleaner in and top end cleaner, still running bad, replaced fuel injector for #4 still running bad. anybody with any ideas, keep in mind that check engine light comes back on with #4 misfire after you clear the code then test drive it. Quote Link to comment Share on other sites More sharing options...
The Dude Posted November 10, 2004 Share Posted November 10, 2004 Do a compression check on the cylinders. It's easy, cheap, and might point you in the right direction. Quote Link to comment Share on other sites More sharing options...
northguy Posted November 10, 2004 Share Posted November 10, 2004 Sometimes it's the easy things we overlook. Since the plugs are in a tough area to reach, you might check to make certain the plug wires are firmly clipped on to the plugs. I've seen people who pushed the rubber boot on, but the metal end of the plug wire wasn't over the end of the plug. Quote Link to comment Share on other sites More sharing options...
Adnan Posted November 10, 2004 Share Posted November 10, 2004 Hi, How about the ignitor? Those do seem to go bad at times. You'd think that an error code would be set for two cylinders as the ignitor is shared, but maybe the computer registers the first one only. I would check the compression first, as has been suggested. Regards, Adnan Quote Link to comment Share on other sites More sharing options...
