EJ22 Swap into EA81 w/ 4spd d/r
11 replies to this topic
#1 88HatchMonster
88HatchMonster
    Back in the Hatch
  • 486 posts
  • South Burlington, VT
Posted 05 January 2005 - 11:04 PM
Is it possible to do an EJ22 swap in to an EA81 utilizing the EA81 4spd d/r tranny rather than converting to an EA82 5spd d/r? If it is possible, would this be a dumb idea or not?
#2 bratsrus1
bratsrus1
    Race car
  • 1,310 posts
  • Selah Washington
Posted 05 January 2005 - 11:20 PM
Hey 88 This is Jerry, yes you can do that with an adapter plate but why. The EA82 5 speed can handle more HP that the 4 speed and they bolth have the same bolt pattern on the bellhousing. A few times really getting on that 4 speed with the EJ22 you will brake that 4 speed. I am not saying you can't brake the 5 speed anything can be broken, but you will be much happer with the 5 speed. Thanks Jerry
#3 ballitch
ballitch
    Certified Subaru Nut
  • 1,000 posts
  • Salem, OR
Posted 06 January 2005 - 04:54 PM
but doesnt the 4 speed have better crawling gear ratios? I have an 86 gl that has the 5 speed D/R, I dont think that i would like the 4 speed, unless you want to make the ultimate subaru-rock-crawler. and what year car will this be going into? i think the 1st Gen. cars have narrower frame rails from what ive heard.
#4 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,140 posts
  • Oregon City
Posted 06 January 2005 - 07:28 PM
ehhh this isn't a first gen car though..... EA81s were gen 2s.....
Yes the gearing in a 4-speed d/r has a slightly lower first gear BUT it cannot handle the power from the EJ22. This is why people are going with the EA82 d/r 5-speed plus it has better gears for the highway as well...
#5 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 06 January 2005 - 08:41 PM
what do you guys mean it can't handle the power?
#6 lepetitprince
lepetitprince
    USMB Irregular
  • 384 posts
  • Madison Heights
Posted 07 January 2005 - 03:22 AM
According to Austin, it seems like ej22 conversion into older subarus doesn't necessarly need d/r tranny. He didn't really specify the reason why, but it would be best to ask him and find out. If that is true, you don't have to spend time and money making an adapter plate or spend money on buying one.
Dan
#7 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 07 January 2005 - 02:24 PM
ok, confused ones...
the 5 speed has a better crawl ration than the 4 speed dr.
the 4 speed dr should be able to handle the same amount of power. as far as my research showed. the gears are the same width, and made out of presumably the same metal 4 or 5 speed.
i have a 4 speed hooked to a 6 cylinder. i have floored it quite a bit now, and it shifts smoother than any 5 speed i have ever touched.
you dont NEED a dual range, but if your goin offroadin, with bigger tires, dual range is the only option.
#8 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 07 January 2005 - 03:04 PM
I just crunched some numbers... Common factors were 3.9 final drive gear ratio and 28.9 (235/75R15) tire size. These were used in the crawl ratio calculation. Differenciating factors were tranny gear ratio and low range gear ratio. http://www.s-series..../crawlratio.htm
5spd Dual Range Crawl Ratio: 22.01
4spd Dual Range Crawl Ratio: 20.3
It's rather confusing just looking at tranny gear ratios. The key is that the 5spd has a Low Range gear ratio of 1.592 while the 4spd Low Range gear ratio is 1.462 That minor difference in Low Range more than makes up for the minor difference in tranny gear ratios.
Tranny info was derived from http://www.ultimates...5spd gear ratio
I can not vouch for it's accuracy as JWX copied it from another source so who knows where the data came from. I know JWX wouldnt lie about it or anything but its tough to say where the info came from. Looking at all the info in that thread there is some minor variances in gear ratios based on where the data came from (or what application and/or year).
#9 JWX
JWX
    Lonely driver
  • 3,073 posts
  • Atlanta
Posted 12 January 2005 - 01:29 PM
I think mine came from a FSM, but I could be wrong its been awhile since I copied and pasted it.
#10 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 12 January 2005 - 02:21 PM
I copyed these from the board awhile ago
It prolly did come from an FSM originally. Who knows by now :-\
#11 RavenTBK
RavenTBK
    Professional Auto Thief
  • 661 posts
  • Apalachicola Natl Forest
Posted 12 January 2005 - 08:55 PM
I'm still waiting on some more documentation about the swap.. primarily the wiring issues.
Whens John or Austin gonna chime in with a writeup?
#12 88HatchMonster
88HatchMonster
    Back in the Hatch
  • 486 posts
Posted 12 January 2005 - 09:59 PM
I originally asked the question because I am contemplating an EJ22 swap into my lifted hatch. I just wanted to weigh all of the options. If I do the swap I will get a 5 spd d/r now that I know it has a slightly better crawl ratio. Might as well if I'm going to do all of the rest of the work involved in the EJ-EA swap.
I've got my eye on 4 early legacy's in backyards all along my commute to work through northern NY and VT! I just gotta save $200-$250 or so and get up the nerve to knock on some doors...
