ballitch Posted June 22, 2005 Share Posted June 22, 2005 After some searching i found the front accord springs conversion, from a 86-88 accord. however, i came across the fact that RX front springs will fit and have a little better spring rate and are the same size, is this for sure true or someones vague advice? found accord front springs for like $60 shipped which is an awesome deal, plus they are new springs and not used. any help fellas? ~Josh~ Quote Link to comment Share on other sites More sharing options...
subynut Posted June 23, 2005 Share Posted June 23, 2005 The front accord springs mount on the rear of our Subies. That'll give you a taller ride height and a stiffer ride when empty. I think the RX front springs are the stiffest of the bunch. Quote Link to comment Share on other sites More sharing options...
ballitch Posted June 23, 2005 Author Share Posted June 23, 2005 thx man, i just hope the RX springs are the same height, im going to cut down the accrod springs to go back to stock height. well maybe a custom 1/2'' lift is in order.... ~Josh~ Quote Link to comment Share on other sites More sharing options...
mcbrat Posted June 23, 2005 Share Posted June 23, 2005 I believe all ea81/ea82 springs are the same height unloaded. Just the spring rates are different. I have a set of RX springs on ea81 struts in my 82 Brat. it lifted my front end 1-1.25".... of course, that was a lighter front end, so it may not lift yours as much..... Quote Link to comment Share on other sites More sharing options...
ballitch Posted June 23, 2005 Author Share Posted June 23, 2005 i guess that settles it......ill get my grubbies on some RX front springs. ~Josh~ Quote Link to comment Share on other sites More sharing options...
