Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Rust Converters you have used?
#1
Posted 23 June 2005 - 07:35 AM
Anyone have a strong recommendation for or against any particular rust converters?
Thanks.
#2
Posted 23 June 2005 - 10:23 AM
I use a phosphoric acid (could be spelled wrong). I think it's made by Dupont and is sold at auto body supply stores as a metal primer.
It's a green liquid that converts rust to shiny metal or a black color depending on the extent of the rust. It etches the metal and is ready for priming/painting in about 10 minutes...
Is this what your talking about?
Good Luck,
Glenn
82 SubaruHummer
01 Forester
#3
Posted 23 June 2005 - 10:45 AM
So dont forget POR-15
http://www.por15.com/
ALSO try this stuff
Par-Al-Ketone - Its used for airframe corrosion resistance.
An excellent corrosion inhibitor for use on exterior surfaces of parts that are subject to exposure. Recommended for all control cables. Meets spec. MIL-C-52, Type 1. May be sprayed, dipped, wiped or brushed on. Thin with mineral spirits or use undiluted.
http://www.aircraft-...paralketone.php
#4
Posted 23 June 2005 - 11:00 AM
Glen can you give me the specific name of the Dupont product...they have a million at the autobody supply.
Scott
#5
Posted 23 June 2005 - 11:13 AM
For those who don't know what a "rust converter" is, it is a material that combines with the iron oxides that constitute rust and turn it into a relatively inert compound. It will typically leave the surface a dark purplish color (along with your hands, clothes, dogs). The treated surface can be painted, but if heated to high temperature (e.g. exhaust surfaces), it will convert back to iron oxides.
I have heard good things here about POR-15, but was unaware that it was a paint/primer material. I have used another product, but can't remember what it is called (I bought it at WalMart); it worked satisfactorily.
#6
Posted 23 June 2005 - 11:58 AM
Thanks guys.
Scott
Northwet is right, it seems it might be a professional Navel Jelly type product.
The "professional"
I'll take a look when I get home and see if I can still read the writing on the bottle. I remember it being called Metal Primer by 3M or Dupont. It was not packaged for consumers.
For what it's worth, I have had mixed success with this stuff. On some projects it worked and some the rust reappeared a year or two later although that could have been attributed to my painting?
#7
Posted 23 June 2005 - 05:09 PM
#8
Posted 23 June 2005 - 05:17 PM
Actually better than POR 15, but similar in many ways. It works great! I recommend it highly.
Todd
www.rustbullet.com
#9
Posted 24 June 2005 - 02:07 PM
#10
Posted 24 June 2005 - 03:19 PM
#11
Posted 29 June 2005 - 12:26 AM
#12
Guest_shadow_*
Posted 29 June 2005 - 03:25 AM
It is faster to use, less prep work is required, and it seems to me it leaves a harder coating in my own experience. I have used it on a friends car to respray critical surfaces such as frame rails/support structures on the underbody and wheel wells, and anywhere that had previously experienced rust on the body. It is also possible to apply in spray form, I used a 1.8mm tip and it sprayed nicely without thinning. I am currently using it on both of my RX projects as well.
#13
Posted 29 June 2005 - 07:49 AM
Thanks.................
#14
Posted 29 June 2005 - 03:02 PM
I would work hard to maintain the paint. Keep it clean and touch up chips.
I would consider removing all interior panals to access the interior of doors and rear quarters. Clean all the dirt out and coat the inside ith rust bullet from the bottom up about 8 inches.
Do frame rails and the insides of the front fenders too. Also the radiator support.
Don't sand off your paint!
Todd
#15
Posted 29 June 2005 - 03:05 PM
