bgd73 Posted July 13, 2005 Share Posted July 13, 2005 I really need to change my wheels on my highwayed 93 loyale 2wd(4 lug). I would like 15 inch. I have found other posts with alot of work I do not find worthwhile for this "conversion".I cant seem to keep it contently balanced all the way around, (while parts necessary to keep it so are good) on long trips@ high speed (struts go weak to those little benders?).I have 12 oem wheels, 8 new tires mounted and I cant make it good. I have thought of the struts, but every make and model car I've had with 13" wheels really sucked at higher speeds(65-70mph they seem to start throwing thier flaws at me).I would like to drop the height of the rubber and give it bigger on the steel/aluminum wheel. Any cheap ideas? (not pertaining to post; these are other things I've had to "fix" on my 93 loyale): http://users.adelphia.net/~barrygd73/suby.html thanks! Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 13, 2005 Share Posted July 13, 2005 15" rims No modifications needed Bolts right on: Same for 14": You can find 4x140mm rims from some older Peugeot's. They're available in 14" and 15"... steel & alloy. -Brian Quote Link to comment Share on other sites More sharing options...
bgd73 Posted July 13, 2005 Author Share Posted July 13, 2005 thanks, will start the search...... Quote Link to comment Share on other sites More sharing options...
ballitch Posted July 13, 2005 Share Posted July 13, 2005 need not forget the toyota rims, 15'' alloy, and steel, and more plentiful, as well as cheaper. ~Josh~ Quote Link to comment Share on other sites More sharing options...
Bobby_boucher Posted July 14, 2005 Share Posted July 14, 2005 need not forget the toyota rims, 15'' alloy, and steel, and more plentiful, as well as cheaper. ~Josh~ What Year Yota rims??? and are there any mods needed? Quote Link to comment Share on other sites More sharing options...
EYE_WHY Posted July 14, 2005 Share Posted July 14, 2005 hey bgd, I have been looking for some bigger wheels too. I found a set of four pug wheels at Silver's Auto in Orono, the guy said they weren't very pretty, but they would do the job just fine. I passed them up, so they're yours if you want. Quote Link to comment Share on other sites More sharing options...
MorganM Posted July 14, 2005 Share Posted July 14, 2005 Be sure it's not the metric ones and that they are truely 15". Quote Link to comment Share on other sites More sharing options...
iluvdrt Posted July 14, 2005 Share Posted July 14, 2005 need not forget the toyota rims, 15'' alloy, and steel, and more plentiful, as well as cheaper. ~Josh~ Those are not direct bolt on wheels, which he is looking for. Quote Link to comment Share on other sites More sharing options...
