found an easy exhaust manifold bolt fix
15 replies to this topic
#1 dragonwingsubaru
dragonwingsubaru
    Subaru Nut
  • 512 posts
  • englewood
Posted 31 July 2005 - 07:30 PM
well after listening to my sooby sounding horrible for about a month, i finally decided to get around to fixing it. what had happened is i had managed to strip out 1 bolt hole on each side. well the other day i dug into my coffee can of bolts from when i had stripped my 87 and found 2 brass looking bolts with a double washer setup on them and a slightly tapered end. (im not possative but i think they were from the rear tow hooks) anyways they threaded right into the holes and snugged up real nicely and stopped the exhaust leak completely. i gotta take off my tow hooks tomorow to bolt up my trailer hitch, so ill check out the bolts and see if that was where those bolts were from.
#2 TurboSPFI
TurboSPFI
    Banned
  • Banned
  • 374 posts
Posted 31 July 2005 - 07:32 PM
Ah the random bolt trick... Doesn't work all the time :D
#3 markjs
markjs
    USMB is life!
  • 183 posts
  • Port Townsend, WA
Posted 31 July 2005 - 08:21 PM
The best fix I found for this same problem is to take a 7/16th tap (assuming the original was a 10mm diameter bolt) and tap out the stripped hole with it. Works perfect with no drill or pricey Heli-coil. I used a fine thread (7/16-14) and used a dual thread (fine and course on opposite ends) stud.
#4 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 31 July 2005 - 10:02 PM
I do the same thing but with 3/8 exhaust studs. Works great
#5 Tin Soldier
Tin Soldier
    Wannabe awesome guy.
  • 555 posts
  • Franklin, PA
Posted 02 August 2005 - 08:02 AM
I went to everybodys favorite auto parts store (insert heavy sarcasm here), Advanced, and bought a toyota Corolla manifold kit (you actually need two for a sube). This kit includes two bolts and three exhaust studs.
I tapped the hole using one of the bolts. :brow: Then I put high temp locker on the one end of the stud and high never seize on the side the nut goes on and screwed it up in there. :)
Seemed to work better then the bolt trick. Especially if you want to be able to take your exhuast off for upgrades/oops a rock or something like that.
#6 NewDriverOlderRide
NewDriverOlderRide
    Eat, Live, Breath Subaru
  • 300 posts
  • Ft. Myers
Posted 29 April 2007 - 12:30 AM
Sorry to ressurect such an old thread, but I am in the middle of needing to do this tomorrow, so what is the best way to do it?
Thanks, Tyler
#7 ecky
ecky
    USMB is life!
  • 132 posts
  • Roseburg, Oregon
Posted 29 April 2007 - 12:52 AM
My brother went down to the hardware store, and bought a course threaded SAE bolt a little bit bigger that the hole. Then, took a !/2 impact gun and just pounded it in there:lol: Wouldn't recomend it, but it works.
#8 joostvdw
joostvdw
    Subaru Nut
  • 609 posts
  • Holland
Posted 29 April 2007 - 04:44 AM
just go to a toyota dealer and get some exhaust studs and nuts there, it's the exact same diameter and pitch as subies (M10x1.25) and won't cost you an arm and a leg
just don't screw around with american sizes in there :rolleyes: get the proper bolts or don't bother at all.
#9 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 29 April 2007 - 04:54 AM
if the threads are stripped out, then supposedly you can tap it out to 7/16" thread of a similar pitch without drilling any further.. just work the tap in 1/4 turn at a time and back it out.. but thats just hearsay. there was a big long hotly debated thread about this that was last posted in oh, say a week or ten days ago. go find that and read it through for all your options. there were like 80 replies.
#10 chef_tim
chef_tim
    Romans 5:8
  • 4,780 posts
  • Renner, SD
Posted 29 April 2007 - 07:42 AM
Oh yeah, forgot this too. I think a 1/4 8 point socket will hold the tap so you can put an extention on it and then use a ratchet handel to turn it. Makes it alot easier as your not fighting the tap handle in a confined space. Tim
#11 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 29 April 2007 - 08:26 AM
toyota bolts are generally x1.00 threads. or was it x1.50? i do know its different. but that makes sense if they thread into soob exhaust holes if they are stripped out
#12 NewDriverOlderRide
NewDriverOlderRide
  • 300 posts
  • Ft. Myers
Posted 29 April 2007 - 09:20 AM
Well, the manifolds are "semi-stripped." So I guess Im gonna try the 7/16 tap thing......Hopefully, my buddy has a tap.:-\
#13 Gloyale
Gloyale
    It's a sickness
  • 10,930 posts
  • Corvallis, OR PNW
Posted 29 April 2007 - 01:26 PM
Do the 7/16 studs. That is the best way. Leaves room for a bump up to 12mm or for a helicoil in the future. Don't need to drill, just go slow and careful with the tap. And use lots of oil and don't force it.
#14 daeron
daeron
    Cunning Linguist
  • 3,600 posts
  • West Palm Beach
Posted 29 April 2007 - 01:35 PM
Yah, I was just repeating what I had heard gloyale say in a previous post. listen to him, not me; I havent been there or done that. I was just tryin to help :)
#15 operose
operose
    1000+ Super USER!
  • 1,264 posts
  • Potsdam
Posted 29 April 2007 - 09:38 PM
I've done it with 7/16" stainless bolts
works fine :banana:
but I'd use studs if I did it over, as I take my exhaust off a lot, and will probably get some studs in the future
#16 Quidam
Quidam
    1000+ Super USER!
  • 1,622 posts
  • USA
Posted 29 April 2007 - 10:52 PM
Hey Miles,
My "Muffler Man" sold me a dozen 10X1.25 studs, nuts and washers. This for Justy exhaust, converter to front pipe, and some spares
He did indicate, I think, that Mazda took the X1.50 and I believe he said most other Asian stuff uses the X1.25. YMMV, of course.
Later
