Dyno'd the turbo engine today
50 replies to this topic
#1 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 17 December 2005 - 09:27 PM
As some of you may or may not know, I rebuilt and swapped an ej22t engine from a turbo legacy into my legacy. The motor's broken in, and I took it to the dyno.
I got 153 HP at the wheels, and around 156 ft-lbs of torque.
Not too bad for a pretty much stock ej22t with bolt ons. The dyno I was on doesn't use any correction factors, so it's pretty accurate, and is probably lower then most.
Other interesting note is the tuner guy mentioned I'm running a little lean until about 4500 rpm, most likely due to the fact the small turbo builds boost so fast, but then I'm running a little rich afterwards. So a little tuning will probably smooth out the AFR. Boost level stayed pretty consistent across the entire rpm range.
http://www.main.expe...s/tlegdyno1.jpg
http://www.main.expe...s/tlegdyno2.jpg
Pics of the engine rebuild & swap if you haven't seen them.
http://www.main.expe...ru/images/ej22t
#2 TheBrian
TheBrian
    Eat, Live, Breath Subaru
  • 270 posts
  • Buffalo
Posted 17 December 2005 - 10:29 PM
What sort of bolt-ons?
Stock is "
HP 160@5600rpm, torque 181@2800rpm" (cars101.com). Of course, that's BHP, not WHP. I'd love to know how much driveline loss a Legacy experiences.
How long did it take to sweep from 3000 to 6000 rpm?
Pet peeve: They should start the test at the lowest rotational velocity that can support WOT, which is probably more like 2000RPM than 3k. Seeing as I usually shift at 3k, dyno charts like this one are not so relevant to me. Your peak torque is below 3000, so even a performance tuner would want data down in that range.
#3 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 17 December 2005 - 10:44 PM
Bolt ons
MSD Dis 2 ignition
Stock sized lw pullies
lw flywheel
magnecor 8.5mm wires
CES 3" turbo back exhaust
modified stock air box
I did datalog during the pulls. I'll have to check the time. Yeah, as for starting at a lower rpm, that would have been better. I mainly just wanted a baseline before I started doing any other mods, so I had an idea of how much I gained.
#4 sasquatch
sasquatch
    USMB is life!
  • 230 posts
  • Vancouver
Posted 18 December 2005 - 12:31 AM
over 150 whp is very respectible. That must be fun....what kind of mileage are you seeing? Congrats.
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 18 December 2005 - 12:23 PM
On the highway if I'm behaving....around 20ish. Around town 16-17 when I'm on it.
I need to check my most recent couple of fill-ups though....I haven't checked them.
#6 Strakes
Strakes
    Kaboom? Kaboom?
  • 520 posts
  • Knoxville
Posted 18 December 2005 - 01:55 PM
Very Nice! Plus, it's better than a new car, and no payments!
#7 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 18 December 2005 - 06:13 PM
this sounds like a lot of fun. That should be a pretty peppy car and you can be proud of the work you have done!
#8 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 18 December 2005 - 07:09 PM
About 5 seconds.
Here's logs from my dyno runs. The battery on the laptop died on the first run, so I just have the last two.
http://www.main.expe.../pplogging2.xls
#9 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 18 December 2005 - 07:11 PM
Thanks guys! :)
Yeah it's a pretty fun car to drive around. This is the beginning though. With a larger turbo & injectors, upping the boost, and tuning, I don't see any problem with putting out another 100 hp with the setup I have.
muwahahaha :D
#10 Lawsonmh15
Lawsonmh15
  • 298 posts
  • Denver
Posted 18 December 2005 - 07:45 PM
Nice Work Man!!! :banana: That engine compartment is as clean as they come. VERY NICE job. I Especially like the addition of the Optima Yellow Top. :grin:
#11 BigMattyD
BigMattyD
    Subaru Fanatic!
  • 405 posts
  • Syracuse, NY
Posted 19 December 2005 - 10:37 AM
Josh,
Do you have any dyno charts from the pre-turbo engine?
It would be cool to see the difference.
Great job, wish I had the time, talent, and tools to get a job like that done (and the money)
By the way, did you keep track of the amount of money invested into the turbo swap??
Matt D
#12 Jerry DeMoss
Jerry DeMoss
    Pushrods 'O' Fury
  • 2,408 posts
  • Colorado
Posted 19 December 2005 - 10:59 AM
Very nice pictures.I like that you took the time to take pictures of the tear down as well.I really like it.Thanks for posting them.
#13 beezer
beezer
    USMB is life!
  • 210 posts
  • Paris, Canada
Posted 19 December 2005 - 06:08 PM
Good job!
It almost looks as good as my car..............yeah right! Cleanest part on my car is the hood latch!
What kind of boost are you looking at running?
Is there any issues with the trans when adding that kind of power?
Will you have to upgrade the cooling system? You still have the NA rad right?
What does it cost to put your car on the dyno?
Good job again!
Beezer
#14 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 20 December 2005 - 02:23 PM
Josh,
Matt D
Yeah, I've got a dyno chart from the n/a ej22 motor. Remember it's a completely different motor. Also, it's a different dyno, so you really can't do an apples to apples comparison.
http://www.main.expe.../legacydyno.jpg
Yeah I kept track of all the costs. With all the performance parts and rebuild I've got just a little over $7,000 into it. I'll do a write up like I did with the AWD & 5MT conversion when I get some time.
#15 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 20 December 2005 - 02:28 PM
Good job!
Good job again!
Beezer
Honestly, I really don't have any idea of what sort of boost I'm going to run. It's still up in the air. It'll probably depend too on the turbo, and where its efficiency ranges are.
Yeah there are probably some issues with putting down that much power through the transmission. I may/hoping will be alright, but I'll just have to wait and see. I won't be doing any AWD clutch drops though.
There was some discussion about the cooling system and using the n/a radiator on the legacycentral bbs. I am having zero cooling issues, temps are running fine. I'm running just shy of a 50/50 mix, and redline water wetter. Unless I have issues, which I don't think I will, I'm not going to worry about it.
This last time it was $50 for 3 runs and a/f ratio monitoring.
Thanks for the comments guys!
#16 tjZ06
tjZ06
    USMB Regular
  • PipPipPip
  • 40 posts
  • San Jose, CA
Posted 20 December 2005 - 05:59 PM
Not to rain on yoru parade, but I do better than that in my 442 RWHP Z06. I'm looking into an EJ22T sway myself and was hoping to see better. :(
-TJ
#17 cookie
cookie
  • 3,058 posts
  • SFO
Posted 21 December 2005 - 11:43 AM
mileage, at least the late ones. My friend Doug does better with his 05 Vette than I do with my BMW M Roadster.
You are never going to get truly great fuel mileage out of a boxy little four wheel drive car with a high numerical gear ratio. One of the reasons for the Vette's good mileage is the high rear end and economy and emissions gearing (love that six speed in Doug's car.)
I am sure fuel mileage was not a main point of this excercise. What Josh has right now is a little sleeper that did not cost a lot of money and has the pride of building it yourself. It would be nice to get better mileage too but you need to have the parts to do that in the Subaru inventory, and anything that might help is too expensive for a project right now.
#18 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,358 posts
  • Columbus
Posted 21 December 2005 - 12:49 PM
wow, nicely recorded work. you should write in step by steps
#19 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 25 December 2005 - 04:39 PM
The stock turbo is a tiny turbo. With a larger turbo mileage will be better.
As I mentioned this is just the initial setup....
#20 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 25 December 2005 - 04:41 PM
Thanks!
I'll be doing a write up similarly to my AWD & 5MT swap. I'm not going to do a step by step of everything, but will try and do an overview of the main issues.
#21 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 26 December 2005 - 04:20 AM
Nice Josh, liking your torque curve already :)
Of course, being a cautios man myself, I would run a bigger radiator. Have you tried comparing the two? Euro turbo rads much bigger than NA.
#22 idosubaru
idosubaru
  • 23,769 posts
  • East Coast
Posted 26 December 2005 - 05:04 AM
you're not raining, you're bragging and comparing apples to oranges. congratulations.
#23 Ranger83
Ranger83
    Subaru Nut
  • 740 posts
  • Northeast
Posted 26 December 2005 - 08:13 AM
Not to rain on yoru parade, but I do better than that in my 442 RWHP Z06. ///
-TJ
Yup, that's pretty much why everyone I know $70,000 on a Z06 Corvette - operating economy.
#24 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 26 December 2005 - 05:08 PM
The turbo radiator is taller, and without modifying the lower radiator support, it's not going to fit. I don't feel like messing with that. I'm running a lower ratio of anti-freeze & water as well as redline water wetter. I have not seen any issues what so ever, temps are maintaining where they need to be. If I find that I'm running warm, I'll probably look at a custom two row n/a sized radiator, instead of the one row.
#25 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 27 December 2005 - 02:10 AM
I don't doubt that your present temps are fine, but if you do some "spirited" driving you might like the extra cooling capacity.
If your rad is presently working at 90% to keep things in check, then you're not far off an overheating situation - especially with a bigger turbo :-)
Just a suggestion from a careful man. Please consider that I have BIG respect for your skills :D
