Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
XT 5Spd AWD W/Center Diff Lock in an EJ (1998 Legacy)??
#1
Posted 30 December 2005 - 12:43 AM
Definately Needed:
EJ-EA Engine Adaptor Plate.
EA Flywheel/Clutch (Redrilled?)
Matching Rear Diff (3.90)
Rig a vaccum pull for the Diff Lock
Unknown:
New Driveshaft (shorter/longer?)
Different Crossmember?
Anything Else?
If I could get this to work out, it would be great, as I would have AWD on the street (which I like, as spinning wheels in the rain does not really excite me), and be able to lock the center for some trail running....still no low-range, but going from the 4.11 to the 3.90 would "correct" my gearing from my lift and bigger tires (pictures forthcoming) regardless, so I would essentially be back to stock gearing, and I am willing to give up the dual range to retain the AWD (as opposed to swapping an EA d/r in).
Any help is greatly appreciated!
#2
Posted 30 December 2005 - 01:22 AM
the axle shafts will likely be an issue. can't imagine the XT axles will match your hubs or the '98 axles will match the trans and rear diff. shops can make a set of correct axles for you though.
you'll need the solenoid(s) for the diff lock button to work. although you could probably fab some other kind of actuator to work. never heard of that being done before though.
best bet would be to pick up a junked car with a good trans that you want, XT 5 speed like you said.
#3
Posted 30 December 2005 - 10:05 AM
XT6 AWD trans w/ diff lock and 3.9:1 ratio
trans shift linkage
matching 3.9:1 diff
solonoides and switch for diff lock
drive shaft
trans cross member (its a parts from a couple different cars but should work)
i even have the covited XT6 flywheel and clutch kit (used of corse)
looking to get $350 for it all. but shipping would kill.
#4
Posted 30 December 2005 - 12:31 PM
So basically the swap would be mechanically similar to the EA dual range swap? If this is the case, it sounds like it would not be too bad.
#5
Posted 30 December 2005 - 01:11 PM
I am sorry to inform you that this is incorrect.
It would make matters worse
the taller tires are the same as numerically lowering your diff ratio,
meaning you go further with each drive shaft revolution.
Not what you want for wheeling or correcting your gearing.
To "correct" your gearing for tall tires you would need to go to a 4:44 ratio.
4.11
one Drive Shaft revolution = (1 /4.11) x revolution of the tire
rev of the tire = Pi x Dia (24" )
one DS rev. = 18.33 inches
3:90
one DS rev = (1 /3.9) x rev of the tire
one DS rev. = 19.33 inches
#6
Posted 30 December 2005 - 02:41 PM
#7
Posted 30 December 2005 - 05:38 PM
but on this side of the pond
we never got that tranny
#8
Posted 30 December 2005 - 06:52 PM
- XT6 came out with a 3.9 FT Single Range 4WD Box Correct?
- Is there such thing as 3.9 FT Dual Range that can go into an RX?
Also the EJ tranny would not be lockable? Am I correct in saying that? The Australian EJ models have dual range - but the "low range" is fairly poor in stock form.
#9
Posted 31 December 2005 - 01:13 AM
rule of thumb is if its turbo it got 3.7:1 if it was N/A it was 3.9:1
Hmmm - a slight hijack but I'd like some clarification if possible.
#10
Posted 31 December 2005 - 01:35 AM
Ahh got it! So can you bolt a 3.9 Single Range FT Tranny to an EA82?to my knowledge you are right with the XT6 but no 3.9 was ever in the FTDR in the RX they were all 3.7, and we never got a DR in any EJ and none are lockable, just FTAWD.
Sounds like we Australians (and NZers apparently!) got the lion's share when it comes to the later model cars regarding gearboxes. I have heard of people taking the 1.592 gears and placing them into EJ Dual Range boxes - just to have decent crawling ability.
Thanks for clearing that up for me hey
#11
Posted 31 December 2005 - 09:18 AM
#12
Posted 02 January 2006 - 12:20 PM
http://www.ultimates...3:90 LSD tranny
Also, This is first hand info, I've gathered from all the MANY CARS I"VE BUILT AND DRIVEN....
A Legacy or Outback or Forrester is a car with an engine pushing 135-165 hp..in a car weighing roughly 3500 lbs give or take...Also running 14-16 inch wheels...
If you take a 3:90 trans out of a car that had a motor running 90-102 hp and wheels in the 13inch rage and you stuff it behind the bigger motor it will effectively be Ok even with larger tires....
Example...I took a 4:11 AWD 5 speed out of a 98 Forester....and replaced it with a 3:90 2WD Hi-Lo tranny from a GL....We stuffed the Phantom LSd in the front diff, and a stock Subi LSd in the rear Diff....He runs 27-28 inch Mud terrain tires on it and It gos as well if not better now than it did before....
When thinking about this you need to remember Subaru Geared 1-5 in the 3:90 for 13 rubber and less hp....and they geared the 4:11 box for more hp and bigger rubber......
Make Sense...? Good....John
#13
Posted 02 January 2006 - 03:12 PM
If I was closer, I would probably just take it to Mudrat to get the EA Dual Range LSD swap done, but shipping would not be fun to the other side of the country.....I was hoping to put something together myself.
Thanks, keep the info coming!
#14
Posted 03 January 2006 - 06:25 AM
#15
Posted 03 January 2006 - 05:33 PM
