EJ wiring harness questions
[HTi]Johnson
Hello all. I was wondering if there is a difference in the front harness between years of EJs. I don't mean Ej22 is different than ej25...i mean did they change the harness in the years within the EJ22?
I'm talking about the front harness that is required for conversion/transplant into an EA series.
Thanks all for your time.
Justin.
yes, many differences, DO NOT use somnones wiring colors for any given harness, chances are its NOT the same and will not work for you. your just going to have to buy a haynes or chiltons manual with the wiring diagrams and figure out which harness you have and mark all the wires form the ECU, and trace them to whereever they end. long and tedious, but well worth it.
~Josh~
