I have an '84 GL Wagon with a Carter-Weber carb (therin probably lies the problem) and the choke started sticking shut so I had to rip the spring off in a pinch to keep her running for the night. Trouble is, now the spring is destroyed and there is no such thing as a rebuild kit for this carb. Please don't tell me to get a Hitatchi or a Weber. The car is a beater, soon to be replaced, and I have no money to speak of so changing carbs when other than being damn hard to start, this one is working fine, would be senseless. Can I find some sort of universal manual choke cable assembly that I can make fit?
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Manual choke?
Started by
markjs
, Feb 02 2006 09:13 AM
3 replies to this topic
#1
Posted 02 February 2006 - 09:13 AM
#2
Posted 02 February 2006 - 09:19 AM
Other than attempting to repair the choke, there is no manual adaptor availible for them - just as there are no rebuild kits really. Best bet is to find a spring at a hardware store that is similar and try to repair the "sticking". Other than that.... you could use some ether to start it every time I guess.
#3
Posted 02 February 2006 - 10:45 AM
I used a piece of wire and permanently 'closed' the choke for winter when I was driving my '86 wagon. The carb was gummed up so the choke would work when the engine was hot, but then it wouldn't close when it cooled down. I sure fixed it good!
Gas mileage was bad, but at least it ran and warmed up well. When spring came, I just took the wire off and it was fine.
A wire will work in a pinch until you can find a wreck with a replacement carb.
#4
Posted 02 February 2006 - 11:28 AM
get a can of "deep creep".and spary the livin hell out of it..buy a new spring and it should free up qa bit.you can also find another throttle cable bracket,a long piece of like, two inch metal and drill some holes attach it where you can and just put a pull lever on it.you can find al sorts of things at your local hard ware store.your not building a rocket here,anything that pulls out and pushes in will work,as long as it has a cable that is trong enough.
