What rotors and pads to use?
14 replies to this topic
#1 elmwood22
elmwood22
    USMB Regular
  • PipPipPip
  • 76 posts
  • Deerwood
Posted 08 October 2006 - 12:57 AM
Hello everyone,
Looking into getting the rotors and pads replaced on my 1995 legacy l wagon in the next few weeks. Just wondering what you know of brembo rotors. Any thoughts on 'em? I found these at 1/3 less than the oems. Also, what types or make of rotor are subaru oems? Japan? I plan on replacing the front and rear pads, while turning the rear and replacing the front rotors. This should take care of the slight vibration/shimmy when braking at 55-60mph. Also, I am looking for a "good" rotor and pads, something that will last. I am not hard on brakes so I am hoping to get 60-80k out of them after getting them replaced. In the past this is what I have gotten out of my brakes.
Thanks
#2 2X2KOB
2X2KOB
    Subaru Fanatic!
  • 393 posts
  • Midstate MO
Posted 08 October 2006 - 01:14 AM
Have had good luck with Brembo rotors and Akebono pads, and I'm sure that next time I need them I'll buy them again.
#3 Setright
Setright
    Elite Master of the Subaru
  • 3,176 posts
  • Denmark
Posted 08 October 2006 - 03:11 AM
Yep, Brembo rotors are good.
I prefer Mintex brake pads.
#4 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 08 October 2006 - 05:56 AM
those who know say not ot turn subaru rotors, especially the rear. they are unvented and don't do well. the rears are really cheap anyway. but again, they say not to do it.
Hello everyone,
Thanks
#5 brus brother
brus brother
    Subaru Master
  • 2,232 posts
  • Connecticut
Posted 08 October 2006 - 07:33 AM
I had the dreaded shimmy at braking. I used a discounted online Subie site to order genuine Subaru parts and replaced front rotors and pads on all 4 using the provided shims and grease. Shimmy gone, happy chappy.:banana:
#6 hohieu
hohieu
    Subaru Nut
  • 569 posts
  • Philadelphia
Posted 08 October 2006 - 09:48 AM
Don't know the brand, but the rear rotors on my Forester are made in Japan -- it's stamped on the inside of the parking braking drum.
I'm going the Brembo rotors and Akebono Pads on the Subaru, though I think Bendix rotors (made in the USA) are probably superior but more difficult to find and more expensive. With ceramic pads, Akebono has the market cornered.
#7 ericem
ericem
    First Gen Legacy Master
  • 2,477 posts
  • CANADA Maple,ON
Posted 08 October 2006 - 10:12 AM
hey guys, you know how the rear rotors are not usually vented, is it possible a vented disc will work in the rear? Or do i need a new caliper? And brembo rotors are recommended here?
#8 hohieu
hohieu
    Subaru Nut
  • 569 posts
  • Philadelphia
Posted 08 October 2006 - 10:26 AM
You would need new calipers as there are no vented rotors in production that would fit the Subaru rear configuration. A vented rotor in the rear is not really necessary because they contribute only 10-15% to total braking force.
My mother-in-law's '97 Cherokee is fit with rear vented rotors -- it's a heavier car -- but I don't know that they're really all that necessary. The next generation of Grand Cherokees (99-04) have solid rear rotors.
#9 Mikevan10
Mikevan10
    Eat, Live, Breath Subaru
  • 428 posts
  • Lehigh Valley
Posted 08 October 2006 - 10:33 AM
I am curious as to what the drawback is to turning Subaru rotors (as long as the cut rotor is above minimum thickness).
Mike V.
#10 Setright
Setright
  • 3,176 posts
  • Denmark
Posted 08 October 2006 - 10:44 AM
Sounds like a myth ?
#11 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 08 October 2006 - 10:57 AM
Mike V.
i wouldnt bother, your brakes need to be replaced when they warp, its a waste of time to turn them. They might work at the beginning but then they will warp again, much sooner.
#12 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 08 October 2006 - 11:00 AM
I found these brembo drilled and slotted rotors, they seem real cheap but they dont specifie if they are 14", and do you think they are good quality?
http://cgi.ebay.ca/S...1QQcmdZViewItem
#13 Hodaka Rider
Hodaka Rider
    Original BC Soobnut
  • 1,577 posts
  • Nelson, BC (Canada)
Posted 08 October 2006 - 11:14 AM
Not that can of worms again :rolleyes:
My money (for what it's worth) is on stock or slotted. No drillies.
Even on cars with proper cast holes or factory drilled holes, you're asking for trouble in the snow belt, too.
#14 ericem
ericem
  • 2,477 posts
  • CANADA Maple,ON
Posted 08 October 2006 - 11:22 AM
why u say that? But i guess it makes sense. Think i should just get OEM brakes or get the brembos that arent slotted or drilled just vented?
#15 Hodaka Rider
Hodaka Rider
    Original BC Soobnut
  • 1,577 posts
Posted 08 October 2006 - 11:30 AM
Straight vented Brembos would be fine. I personally like the slotted ones, as I stated, but not everyone agrees. If you decide to go with a more aggressive pad (one that likes some heat in it), then slotted will help give you more bite.
