Coughing Brat...Update
7 replies to this topic
#1 darthsoob
darthsoob
    USMB Regular
  • PipPipPip
  • 94 posts
  • tacoma
Posted 07 December 2006 - 07:56 PM
My little Brat has picked up a cough. It runs just great all through town and on the highway, however when I try to up a hill it starts to miss. The steeper the hill the more it coughs. I looked for vacuum leaks and found the vac advance was bad and replaced it. Still coughing up on the hills though. This weekend I am going to replace all the old vacuum lines, new plugs, cap and rotor and do the timing. My question to the board is this; is there anything else I should look for? Any typical problems this might fit? Thanks to all who take the time to look!
#2 Loyale 2.7 Turbo
Loyale 2.7 Turbo
    The Mighty "BumbleBeast"
  • 7,528 posts
  • Roatán, Honduras.
Posted 07 December 2006 - 08:47 PM
If it´s Carbed (With the Hitachi I Supose) it may be the Secondary Vacuum... Maybe it is Disconnected, or Maybe it isn´t Workin´ Properly...
I Suggest to do all what you said you wanna do, and if Problems Persist, Check Carefully the Secondary of the Craptachi Carb.
Good Luck! :)
#3 P K
P K
    Devil Dog Liaison
  • 1,171 posts
  • Omicron Persei Diego
Posted 08 December 2006 - 03:58 PM
Sounds like clogged fuel filter(s). r/ PK
#4 hatchsub
hatchsub
    Currently Subaru-less :(
  • 2,714 posts
  • Guilford
Posted 08 December 2006 - 04:09 PM
I second the clogged fuel filter problem. Replace both (there is one in front of the tank and one in the engine compartment). Also to check if the carb is operating properly just pull the cover off the air cleaner, start the car and rev it up to see if the secondary opens. It should be opening toward full throttle. Hope this helps some
#5 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 08 December 2006 - 08:05 PM
It could be crap in the carb.
#6 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 09 December 2006 - 02:24 PM
I also agree about checking the fuel filter. It may also be a weak fuel pump causing this trouble.
#7 darthsoob
darthsoob
    USMB Regular
  • PipPipPip
  • 94 posts
  • tacoma
Posted 16 December 2006 - 10:13 PM
Well I was finally able to replace the two filters and it did the trick. Thanks to all who took the time to help!
#8 Cougar
Cougar
  • 6,563 posts
  • Anchorage
Posted 16 December 2006 - 10:15 PM
Good deal. Thanks for the update.
