STI engine swap into 92 loyale?
6 replies to this topic
#1 xbrandonedgex
xbrandonedgex
    New User
  • PipPip
  • 12 posts
  • Sioux Falls
Posted 22 November 2003 - 01:19 AM
How easilly would an STI engine bolt up to a Loyale 5 speed with push button single range 4wheel? Would the engine just tear up the drivetrain? Would the wiring harnesses match up to the different engine/computer? I've just recently started thinking about turning my loyale into a super fast (or even moderately fast) beat up wagon.
Thanks, any info is appreciated :)
#2 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 22 November 2003 - 01:26 AM
It wouldn't bolt up to the trans. Wiring isn't the same. It could be done, but you would want to get a front cut with all the wiring and computer that goes with the sti, plus trans rear end and some of the suspension. Even if you could bolt it to the S/R pushbutton 5spd, all that would be good for is about 30 ft of hard acceleration then ..BOOM!
This has come up quite a few times in various forms over the past couple of weeks. Do a search for further info. Specifically, look for the Ultimate RX
#3 xbrandonedgex
xbrandonedgex
    New User
  • PipPip
  • 12 posts
  • Sioux Falls
Posted 22 November 2003 - 01:33 AM
hmmm, okay. Thanks calebz. How easily would the trans/ rear axle and suspension bolt up? would it involve a lot of rebuilding the floor and body shell to get the parts to fit?
#4 josh long
josh long
    USMB Regular
  • PipPipPip
  • 95 posts
  • Tacoma, WA.
Posted 22 November 2003 - 03:06 AM
the owner of this shop has this set up in his wagon it's sweet!!!
It is on pacific ave in spanaway wa.
#5 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,923 posts
  • Portland
Posted 22 November 2003 - 03:12 AM
Chances are - something like this would end up being more expensive than a used STi. hehe
#6 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 22 November 2003 - 11:59 AM
you konw you arent prepared for something like this when you start off asking HOW EASY.
how bout, not easy at all. call it hard, in fact realy hard. the wiring will be hard, building and welding the mounts in the right place will be hard.
prolly as hard as it gets for a "swap"
#7 Dr. RX
Dr. RX
  • 9,984 posts
  • Sammamish, WA
Posted 22 November 2003 - 12:26 PM
Brandon, the conversion can be done, I've done it, but it is not cheap. If you can get the complete WRX STi (I'm assuming that you are talking about the 2004 model) car it would be a big help, but even a wrecked one of those would cost over 5 times what your current car would be worth in shop room condition. I can't imagine you getting an engine alone for less then $6000. If you would really like to pursue this, send me an e-mail and we can talking about it there.
