jdub Posted November 24, 2003 Share Posted November 24, 2003 I guess I just want to be sure I am doing this right... Rear window defrost grid ('87 GL Wagon) does not defrost. Hooked a multimeter at the right and left connectors after removing them from grid on window. There is no voltage across these two connectors. However, the dual 15amp fuses are fine at the fuse box and the switch lights up, as does the glyph on the dashboard. Is there any other fuse/? I ought to be looking at? This seems so simple: all electrics are "there" but no joy at the rear glass. Many thanks! John Quote Link to comment Share on other sites More sharing options...
TomRhere Posted November 24, 2003 Share Posted November 24, 2003 Not sure where it's located, but there's a relay for the rear deffogger. Sounds like it could be your problem. Do you hear any sound of a click, other than the switch when you push it? If not, I'd bet it's the relay. Quote Link to comment Share on other sites More sharing options...
jdub Posted November 24, 2003 Author Share Posted November 24, 2003 I knew there had to be something else - anyone have any idea where that relay might be located? Or, if someone has an electrical diagram I can go at that... John Quote Link to comment Share on other sites More sharing options...
subiemech85 Posted November 24, 2003 Share Posted November 24, 2003 use a test light clip to ground point to grid test each line until no light, that's where the break is, light should be dimmer as you go from side to side multimeter doesn't work Quote Link to comment Share on other sites More sharing options...
jdub Posted November 24, 2003 Author Share Posted November 24, 2003 Thanks Subiemech. It is not the grid per se, it is the current to either connector at either end of the grid itself. There is no juice at these connetors, but there is at the switch and at the fuses (that is, they are not blown...). I have fixed my Targa rear grid using the paste you refer to. That does take a bit of skill! Many thanks, John Quote Link to comment Share on other sites More sharing options...
jdub Posted November 25, 2003 Author Share Posted November 25, 2003 Sort of a bump - there does not appear to be a relay associated with the rear defrost? I looked at my fusible links and they all seem just fine (there are three). So last call - does anyone know if there is a relay I ought to be looking for? The '88 manual's electrical diagrams don't seem to show anything... Many thanks, Jw Quote Link to comment Share on other sites More sharing options...
Skip Posted November 25, 2003 Share Posted November 25, 2003 Sir J, my diagram does show a relay. It's power is fed by fuses 17 and 18 in parallel The relay coil and the dash indicator are powered by fuse 12. You do not say what fuel system your car has Why would that matter?? A Carb car in 87 with 4wd has no ECU Others fuel systems do The relay mounting may be different as they are above the ECU on fuel injected cars. The relays will be mounted in clusters somewhere up above the st. col. The one you are looking for has these colored wires blue/white red/yellow white/green blue/red Relays may be interchanged to prove one is toast here is what you are looking for Sure hope this helps, would not want you fogged in. I can scan the diagram for you if need be, email me Quote Link to comment Share on other sites More sharing options...
jdub Posted November 25, 2003 Author Share Posted November 25, 2003 I have the carb'd model, so no ECU. So I should look somewhere above the steering column? Are the relays easy to get to (you'd think so!). I'll poke around this afternoon and see what comes up. Many thanks! John Quote Link to comment Share on other sites More sharing options...
Skip Posted November 25, 2003 Share Posted November 25, 2003 John, tried to email you but it bounced, if you want to try again try again using normal email neper at westol.com Quote Link to comment Share on other sites More sharing options...
torxxx Posted November 26, 2003 Share Posted November 26, 2003 how do I tell if my relay is shot? Quote Link to comment Share on other sites More sharing options...
jdub Posted November 26, 2003 Author Share Posted November 26, 2003 Just for future reference.... The relays on the carb'd model sit just above the driver's left knee, above the fuses, in a small rack that features half-round clips that hold the circular upper section of the relay. You will need to remove the lower panel, below the steering wheel. Three screws sit vertically into the panel above it, and three plastic screw-type "flower" holders must be removed on the lower section of the panel. Unplug an electrical block connection to have the panel fully away from the area, and reach up and left to access the relays. The color coding matched exactly what was referenced by Skip. To test a relay, you can swap out a known good one. Otherwise, I do not know what the resistance, etc. needs to be as I combed my manuals and there is no testing procedure for the relay. Many thanks for you help, John Quote Link to comment Share on other sites More sharing options...
