Posted 08 June 2007 - 12:00 PM
price everything out and do the job right. don't try to do the minimum, do it right and it'll last another 100,000 miles. skip something and you'll be kicking yourself later for wasting the time and money. well i should ask first, what kind of shape is the car in and how long do you want to keep it. if you want another few years out of it, it will make it if you do a complete job now.
take the heads to a shop - $40-$80 to mill and test them. replace both gasket, not just one. replace any and every seal you can while yo'ur ein there. specifically replace - cam seals, oil pump seals (tighten the oil pump screws on the back of the oil pump), and the water pump, and the timing belt. also, check all of your timing belt pulleys. most likely one or more will need replacing, they will be noisey and spin way too freely because they lack grease. for a 1991 non-interference engine like you have i would get a cheap aftermarket Ebay kit and install that, they come with all new pulleys and bearings. yo'ure not likely going to want to spend $400 just on pulleys, so $80 for all new pulleys is still better than your 17 year old stock pulleys with no grease. or...you can regrease them yourself for a few dollars in grease, i have a thread posted on how to do that.
replace the thermostat, radiator hoses and radiator caps and any hose you can find....at least check them thoroughly.
use Subaru only on the headgaskets, intake manifold gaskets and exhaust manifold gaskets and i'm starting to lean towards Subaru only on seals as well.
a head set will include everything you need, including valve stem seals, fuel injector seals, exhaust, intake..etc for a head job. probably really expensive from subaru unfortunately.
for the headgasket, make sure everything is perfectly clean and clean the head bolts and the head bolt holes. air tools are a huge plug you can just run a head bolt in and out of each hole a bunch of times to clean it out. cleaning them by hand is annoying. you can reuse headbolts on soob motors.
