Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
weatherstrip rejuvenator
#1
Posted 30 November 2003 - 05:23 PM
#2
Posted 30 November 2003 - 09:24 PM
Originally posted by gbhrps
This may be old hat to some but entirely new to others. You can keep your weatherstripping from freezing to the glass and body of the car very simply by spraying it with silicone lubricant. I buy the spray bomb and attach the 5 inch long spay tube to be able to put the silicone right where its needed, and then I massage it in with my fingers. The weatherstrip goes back to its rich black colour, develops a dull sheen and is extremely pliable, and will stay that way for months. It will even bring back hard, brittle weatherstripping to almost factory condition with enough lubricant and massaging. I bought a 71 Mustang convertible back in 1988 and on the way home with it I got caught in an absolute downpour. I watch the sheets of rain wash up the winshield and go right past the weatherstripping on the convertible top leading edge and onto my lap and the floors. Putting down the top revealed that the original weaterstripping was compressed and as hard as a rock. A half hour of repeated silicone spraying and massaging brought it back to almost new condition. Hard to believe, but true. Try it, and it will become a ritual that you'll do to all our your cars every fall.
Spraying the weatherstripping with silicone is part of the regular maintainance schedule that everyone seems to ignore..... It is right up there with the requirement to change coolant every 2 years / 30,000 miles. I had a hard time convincing someone that coolant is green and should not be rust colored when I stopped to help with his blown rad hose.
I spray my weatherstripping about every second month (as part of a complete car wash). Doing it every oil change is a great idea....
#3
Posted 30 November 2003 - 10:33 PM
Any preference with which silicon, or just whatever walmart/hardware store has in a can?
Thanks again!
#4
Posted 30 November 2003 - 11:31 PM
Originally posted by nickb21
Wow, thanks, must have been reading my mind because I was about to ask the question to this answer! It's going to start dropping down below freezing at nights and once it starts freezing rain, I wasn't sure how I'd be able to open my door!
Thanks again!
Silicone lubricant in a spray can (like WD40), not Silicone adhesive.....
Silicone is Silicone, any spray silicone lubricant will do.....
#5
Posted 01 December 2003 - 02:28 AM
#6
Posted 01 December 2003 - 05:40 AM
Originally posted by forester2002s
I use a solid silicone-lubricant stick. Lasts for years. I run the stick along the rubber seals, and then go over it with a piece of paper towel. Don't apply too much, or else the silicone smears the windows.
I spray a paper towel with silicone lube and apply it. It does smear the windows if you don't hold the doors open to allow the silicone to seap into the rubber. I also coat the "under flap" area of the seal too. It will not last as long as the stick method, but I found that I could not get even coverage with the stick. I usually do this every 2 months or so when I do a very complete car wash, it only takes 10 minutes.
I also spray the door seals liberally with silcone, no problem with smearing there. While I am at it I usually regrease the door hinges too.
I also apply silicone to the edge of the door sail (mirror attachment point), as it is rubber and a sealing point (and also a major area for windnoise problems).
#7
Posted 01 December 2003 - 07:42 AM
Um - guys, when you use the silicone, would you use it normally before or after any car waxing?
#8
Posted 01 December 2003 - 11:46 AM
#9
Posted 01 December 2003 - 11:59 AM
i use it to maintain my spraypaint, acts like a wax, but is spraypaint friendly. but it will dissolve cheap dollar can silver paint. i used krylon and rustoleum blue metallic flake, clearcoated, and wd40 is the best for it
#10
Posted 01 December 2003 - 01:17 PM
Hmm, maybe this is where my windnoise is coming from, it's got a different pitch/noise and happens at different speeds than the roof rack wind noise.
I'll have a go at it, thanks for the great info.
#11
Posted 01 December 2003 - 03:04 PM
Originally posted by MilesFox
i have used wd-40 on my trim, rubber, and interior. i say it does wondes and i love it. i like how it refreshes the interior,
Yeah, if you like being high while driving down the road
#12
Posted 01 December 2003 - 05:02 PM
Based on a recommendation from this board, I started using 303 Aerospace Proctectant. It looks and even smells (somewhat) like ArmorAll, but it is water based, not petroleum based. It's biggest selling point seems to be its "sunscreen" factor.
I find it great on interior vinyl. It's not as greasy and you don't seem to get that "off gasing" of the vinyl that clouds the windows as ArmorAll does. I've been using it on the weather stripping as well (about twice a year). Seems to be working well. 1997 car with no wind noises so far (knock wood). It is also suppose to prevent ozone attack that deteriorates rubber. Safe for your tire sidewalls too.
Just something else that people might want to consider. Girots (sp?) Garage has a similar product (perhaps it's just rebranded, I'm not sure) that others have recommended.
A google search will turn up the websites.
Commuter
#13
Posted 01 December 2003 - 05:15 PM
Silicon leaves bubbles in fresh paint where is encountered.
Best if you get as little as possible on any surface you plan to paint in the future.
You can get a silicon remover to apply before painting and if you spray it on all your rubber you will need this.
#14
Posted 01 December 2003 - 05:20 PM
Gordon
#15
Posted 01 December 2003 - 06:39 PM
#16
Posted 01 December 2003 - 09:21 PM
I find it's great on the dash and tire's. It doesn't have that cheap looking shine like armorall. According to their write-up it provides UV protection and restores built in protection in tires. I even used on my fading black moutain bike shoes and they haven't look that good in 2 years. I'll try it on the weather seals now.
For those interested I came across a good site on car care (i.e. washing, etc) that's where I came across the 303 stuff:
www.detailcity.com
These guys are into cleaning their cars as much as we subaru owners are into subarus
