Seasonal Starting Problems
18 replies to this topic
#1 4FOR4
4FOR4
    USMB Regular
  • PipPipPip
  • 113 posts
  • ALDEN, NEW YORK (BUFFALO)
Posted 15 December 2003 - 01:28 PM
:confused: Thsi the the third year now that with the snow comes starting problems with the '92 Turbo Legacy sedan.
It seems to be temperature related, usually happening after sitting all night or after many hours of sitting.
You turn the key and nothing but a relay click happens. Hold the key in the start position for 30 seconds to 3 minutes and it will start.
When it first started happening I put a new starter in, but problem persisted.
Anyone have any ideas? This is my daughters car and I'd like to resolve the problem so the bitchin stops.
Other than this problem, which only occurs when it's cold, the car looks and runs fantastic @ 170,000 miles! Considering I live in western NY where they put tons of salt on the roads so the non All wheel drive people can drive 60 mph, that's a pretty long life!
Any help would be appreciated
#2 EOppegaard
EOppegaard
    USMB is life!
  • 138 posts
  • Madison, Connecticut
Posted 15 December 2003 - 01:44 PM
First off...AWD people can drive 60 on the roads...great...now try stopping :madder:
Anyways, have you checked the battery? Your electrical system may be lacking in the cold cranking amp department.
#3 4FOR4
4FOR4
    USMB Regular
  • PipPipPip
  • 113 posts
Posted 15 December 2003 - 02:12 PM
The point wasn't that I wanted to go 60, it was more a general slam to those who regardless of the weather feel there is no need to slow down and that the roads should be bone dry even during a blizzard.
The battery has been changed also. When the problem occurs it doesn't even try to spin over, almost like a dead spot on the starter or a key (ignition) switch problem.
If you hold the key on though it will suddenly spin like it should and start right up.
#4 northguy
northguy
    O.C.A.L. Life Member
  • 4,352 posts
  • Chugiak, AK
Posted 15 December 2003 - 02:34 PM
Check the connection on the battery terminals. Sounds like you're holding the switch open long enough to finally get a connection, then it goes. Clean the posts and inside of the cables.
#5 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 15 December 2003 - 03:10 PM
The clicking sound usually is a sign of bad solenoid contacts, but since you replaced the starter, it's probably not that.
Check/clean the connection both on the battery terminals & the starter. If the problem still persists, you may want to run a secondary lead from the pos of the batter to the starter. If the problem goes away then the pos battery cable lead to the starter is probably bad and should be replaced.
#6 4FOR4
4FOR4
    USMB Regular
  • PipPipPip
  • 113 posts
Posted 15 December 2003 - 03:29 PM
I'll give your suggestions a try Legacy777
By the way, my '92 that I'm talking about has the same paint as yours, they look alot alike.
I saw in the marketplace site someone was try to get rid of a spoiler off a '93. It would be a great addition to your car. I'm sure it would fit.
#7 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 15 December 2003 - 06:38 PM
I've already got one ;)
I added one a little over a year or so ago.
here's a couple pics
http://www.main.expe...es/spoiler1.jpg
http://www.main.expe...es/spoiler2.jpg
http://www.main.expe...es/spoiler3.jpg
these are the most recent ones I got
http://www.main.expe...ges/legacyzymol
#8 Nug
Nug
    Lurker/off-topic poster
  • 1,968 posts
  • West Point, VA
Posted 15 December 2003 - 07:32 PM
Maybe it's the ignition switch. How often do they go bad?
#9 nathan
nathan
    New User
  • PipPip
  • 26 posts
  • Washington
Posted 15 December 2003 - 09:11 PM
The last post is on the right track. It sounds like the ignition switch is going, with the mileage and if the car is driven short trip(ie. lots of starts) it would not be out of the picture for the ignition switch to be worn out. As far as temp. related, just grasping, it may be that the contacts shrink just slightly so they are barely not making contact.
#10 BlueTrain
BlueTrain
    Subaru Fanatic!
  • 477 posts
  • MisSOULa
Posted 16 December 2003 - 12:49 AM
i agree with the ignition switch conclusion. try jiggling the key a bit while in "start"..if it makes a contact quicker because of this, it most likely is the ign switch, as they get pretty worn over time.
#11 applegump
applegump
    Eat, Live, Breath Subaru
  • 316 posts
  • CH
Posted 16 December 2003 - 04:10 AM
Do you get a check engine light? I had the same situation a couple of months ago and it turned out to be the crank angle sensor!
#12 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,810 posts
  • Houston, Tx
Posted 16 December 2003 - 09:33 AM
if Ignition switch is bad.....you would most likely not hear any click from the starter solenoid. He's hearing a click and the solenoid plunger is engaging the ring gear. Typically if you have an ignition switch go out, you won't hear anything.....
yes....no.....?
#13 northguy
northguy
  • 4,352 posts
  • Chugiak, AK
Posted 16 December 2003 - 09:51 AM
Always go with the free-to-inexpensive fixes first. Then progress to those that will cost money. Clean ther anodes and connections.
#14 4FOR4
4FOR4
    USMB Regular
  • PipPipPip
  • 113 posts
Posted 16 December 2003 - 11:51 AM
It's around 40 dgrees F today. Too warm to get it to not start.
Purred like a kitten this morning.
#15 1ABAJA
1ABAJA
  • 318 posts
  • Soobville, IN
Posted 16 December 2003 - 11:42 PM
That is a really good idea....a Turbo Legacy....for my daughter to outrun guys in their b!tch cars!
Josh!
#16 northguy
northguy
  • 4,352 posts
  • Chugiak, AK
Posted 17 December 2003 - 08:14 AM
4 for 4, there's the answer - move to a place where it doesn't get cold.:-)
#17 4FOR4
4FOR4
    USMB Regular
  • PipPipPip
  • 113 posts
Posted 17 December 2003 - 09:43 AM
What would I do with all the AWD if I didn't have snow to play in?
#18 Nug
Nug
  • 1,968 posts
  • West Point, VA
Posted 17 December 2003 - 03:41 PM
I would break out with a voltmeter and start doing voltage drop tests on the big diameter wires (battery cables, starter wires, etc). And I'd make sure the starter is grounded properly. yeah, i know it's bolted directly to metal. That sometimes doesn't mean anything.
#19 cookie
cookie
    Elite Master of the Subaru
  • 3,058 posts
  • SFO
Posted 18 December 2003 - 07:07 PM
and hook it in line at the solenoid.
If the car starts right up bypassing the ignition switch then you have your problem.
Frankly this car is so old it should have a switch as PM.
You can always install a button.
