weber info... fact or fiction?
3 replies to this topic
#1 archemitis
archemitis
    guy smiley
  • 3,551 posts
  • the big minnie
Posted 15 December 2003 - 08:44 PM
http://www.racetep.c...rk.html#webfuel
looks like a hundred dollar fuel pump they are trying to sell, but im almost ready to order one.
#2 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 20,278 posts
  • Portland
Posted 15 December 2003 - 08:58 PM
That's what I've always heard - summitracing has a carter pump for $60 that is rated at like 6 psi or something - with a regulator, you can get it to exactly 4 if you wanted.....
BTW - our stock pumps are rated at 2 psi.
#3 Negasonic Teenage Warhead
    [ZAP]
  • Moderator
  • 26,957 posts
  • Seattle
Posted 16 December 2003 - 11:37 AM
I've installed five of them on my cars. NEVER did I once use a pressure regulator. Stock one works fine. If you're having problems with your weber, i'd say you did something wrong.
#4 GeneralDisorder
GeneralDisorder
  • 20,278 posts
  • Portland
Posted 16 December 2003 - 02:27 PM
I dissagree Eric - every car is unique, and just because you did not have a problem with any of your pumps, does not mean that someone else couldn't. Also - who's to say that all of yours were running optimally? If you never replaced a fuel pump with anything other than a stock one, then how do you know that it wouldn't have improved the performance or response in some way?
Mine seems to be handling the stock fuel pump alright, but on sharp left turns (like REALLY sharp - into a driveway doing 30 MPH sharp) it leans out, so I think my 20 year old pump is no longer producing the volume that it once was. I will be switching to something like the carter 4070 just to see what difference it makes if anything. It surely can't hurt to try, and seemingly the Weber people agree that 2 psi is not optimal.
It could also be a case that Eric is basically correct - our engines are at the smaller end of the 32/36's spectrum, and the larger volume and higher pressure may only really be needed for bigger engines.... it's hard to say without more Subaru specific test data to go on.
