voltage regulator
4 replies to this topic
#1 murphsubaru
murphsubaru
    USMB Regular
  • PipPipPip
  • 104 posts
  • ohio
Posted 27 December 2008 - 04:57 PM
Is the voltage regulator inside the alternator on a 99 forester??
This morning my battery light came on after starting. I checked the battery while it was running and it is not charging. Fuse is ok, all connetions are clean and tight, belt is good. Car has 130,000 miles, I am guesing the alternator is shot. What else could it be???
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 27 December 2008 - 05:31 PM
You are most likely correct about the alternator. Check to see that the wires going to the rear of the alternator have close to the battery voltage while the engine is running. If so then the alternator is bad. If a wire doesn't have the correct voltage then you need to check for a problem on that wire. You can also take the alternator into Autozone and have them check it.
#3 bratman18
bratman18
    ADIDASubarus
  • 3,843 posts
  • Jefferson, Maine
Posted 27 December 2008 - 07:00 PM
Yes I believe the voltage regulator is in the alternator.
#4 nipper
nipper
    Semi Elite Master of the
  • 18,193 posts
  • Long Island NY
Posted 27 December 2008 - 07:17 PM
Yes.
#5 Rooster2
Rooster2
    Subaru Master
  • 4,687 posts
  • Indianapolis
Posted 27 December 2008 - 08:10 PM
Alternator is an ez swap out do it yourself job. No special skill or tools required.
