Everything posted by Dickensheets
I just did all this 6 months ago. I didn't use special tools. I have a few recommendations though: 1) loosen crank bolt and cam bolts with the old belt in place and a small pry bar in the bell housing viewing port. 2) For retorquing same, I used a pair of 16" slip joint pliers to hold the cam pulleys stationary (2 man job for me). They have small angular surfaces upon which to grab without damaging the teeth. 3) Take 5 min and remove the radiator - you'll be glad for the extra elbow room. 4) I too used a large clamp to squish the tensioner - slowly! 5) Buy a subaru belt - it has timing marks on it, makes life a little easier.
I would do it for sure. Go to summitracing.com and they have a wide variety of fluid coolers. Heat is the biggest enemy of the automatic transmission. It is said that if the fluid ever reaches 270 degrees F, the unit is toasted. A temp guage might be a good idea since you will be towing. If the nipples on the rad are not labeled in/out and noone else has this info, then pull one off and start the motor briefly - you will have your answer. rd
I knew that was coming.. the sand you see is the only place I felt comfortable stopping for a pic, the sand was more powdery off the path and I did avoid the much of it because I couldn't risk getting my family stuck. On a side note I've had the same car on the beach near Galveston in the powdery stuff. The main difference was the presence of numerous 4x4s there to rescue me if need be - which was not needed. rd
