Everything posted by Dickensheets
ball joint replacement
Dickensheets replied to SparkSVT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Last month I did mine (97 OBW). It was my first. I bought the el cheapo Pickle stabber from AotoZone and it worked fine. Taking my time and consulting my Haynes every so often, the job took me 1.5 hrs. Ryan -
The strap wrench idea is good but won't work on the DOHC. The two sprockets are too close together to slip the strap in. I like the BIG pliers idea too. I was brainstorming in the garage while staring at my motor and came up with my own plan: cut the old t-belt in half, loop around crank and cam, held in place with utility clamps, and tighten cam nut pulling against the crank sprocket. As far as loosening, i'll loosen the cam nuts with the old belt still installed. I'll try the big pliers trick first.
My manual shows some guy doing a t-belt replacement. For the cam sprocket on the DOHC he is using a set of large ChanneLocks to grasp some sort of flange on the interior of the cam sprocket. He makes it look easy - anyone here done that? Clearance between intake/exhaust sprockets (DOHC) is such that I don't think a chain wrench would even fit. Special tool is $47 and would rather have sweet pliers for that money. Ryan
When the light comes on you have 2 gallons left. When filling you should put about 13 gallons in. Very reliable in my car. Carry a gas can and drive till the light comes on, proceed to the pump and confirm the numbers. Hopefully you'll not need the gas can at all but will give you piece of mind if the light fails. Ryan
97 OBW - I AVG 25mpg in mixed driving (my wife mainly). I think this is good since the A/C is constantly on here in Houston this time of year. My gas guage does not work so we fill up when the light comes on. I can get 300-330 out of a tank. 40psi in the tires smooth acceleration drive the speedlimit don't tailgate (every tap on the brakes wastes energy/fuel) Ryan
