Posts posted by jamal
certainly not worth the potential damage to your fuel system and I doubt you could save money anyhow.
Also those octane boosters in autozone don't do anything.
It's a pretty involved conversion. Changing the backing plates means pressing out the hub and wheel bearing to get to it, and then the backing plate also needs to be pressed on/off.
Best way to go is to find a donor rear disc car that's moderately new and swap the whole spindle assembly over.
Unless you're like going to a race track or something, it's probably not worth it.
do you already have discs? If so they'd be the same.
For drums you need the backing plate (which is pressed onto the spindle) parking brake and cables, and brake lines.
what benefit do the valves give?
Can I direct you to the vendors forum?http://www.ultimatesubaru.org/forum/forumdisplay.php?s=&daysprune=&f=35
This is the New Gen forum, for people who need help or want to show off something they've done. Not the forum for selling stuff, esp. under titles meant to sucker people into looking.
PS, there isn't a lot of STI owners around here. We buy whole cars for the price of a set of camshafts.
Backseat mod much?
One other thing is that the ride won't be as harsh with higher quality dampers.
You could run stiffer springs with Bilsteins much more comfortably than with KYBs.
NOTHING for any other impreza/forester/older legacy will fit an 00+ because the rear suspension was completely changed. Some of that stuff has been mentioned in here but it won't work on your car. The only things you can use must be 00-04 Legacy specific.
Bilstein makes some of the best dampers in the world. If you're willing to spend the money I highly recommend it.
sounds like a clutch related problem to me.
Wasn't there a slight facelift in there somewhere?
I found this one somewhere a long time ago. Not sure where the full size version is though.
They'll probably sit a bit higher in the front.
If they're height adjustable the driver's I think will be about an inch or so higher at the lowest position.
I have 02-03 WRX seats and they're almost too high for me at 6'2.
my car came with 14s and had a 16" donut. Then I threw it in a dumpster and have a real spare. I suggest everyone do the same.
Indeed. What makes it worse is that many people have never seen snow, they don't have plow/salt/sand equipment, and many cars do not have tires that work in snow.
I-5 north of LA was closed for like 2 days because of some snow a few weeks ago.
For the record I'm from Missoula.
My eyeballs are about to roll out of my head.
Sorry this was just a little too vague:
One interesting thing of note when you are doing exhaust work - there's virtually nothing to be gained with the up-pipe and headers.GD
One interesting thing of note when you are doing exhaust work - there's virtually nothing to be gained with the up-pipe and headers. The STi's use the same up-pipe as the 90 to 94 EJ22T - it's even the same part number!
That is so, so incredibly wrong. Most WRX up-pipes are catted and swapping them out makes a huge difference in terms of both power and reliability.
The catted up-pipes have a tendency to fall apart and destroy turbos.
example: http://forums.nasioc.com/forums/showthread.php?t=1019991
yeah, it should work. To confirm it's broken I'd try another radio and try one in another car.
Maybe go to a local nasioc meet and ask around?
The real benefit of the 4000s is that they are bigger and have better vanes. 295x25.4mm vs. 294x24mm OEM, and they have some sort of a crazy vane design called "Kangaroo Paw." So that gives more heat capacity and better cooling.
To start, you can put almost any set of Subaru brakes on any other Subaru. If you want WRX brakes on your L or something you pretty much just have to buy some and bolt them on. There are some exceptions, however, mostly relating to the rear, which are explained later on.
Additionally, the 05+ sti has a different bolt pattern (5x114.3 vs 5x100) so those rotors are not compatible with other models.
If your car has rear drum brakes, a disc swap is fairly more involved. I'm not entirely sure on the process but there are more details farther down.
I would also be wary about trying to exchange stuff with the 08 Imprezas. The rear backing plate could be completely different.
So, if you're wondering what brakes you have and what other brakes are out there, I've made this big list of most of the different brakes found on modern Subarus. The information came from a lot of places like brake catalogs (click the rotor size for spec sheets provided by DBASteve), FSMs, cars101, and various threads/FAQs on nabisco and scoobymods. This is mostly just about US model cars. Generally brakes were the same around the world but there are a few little special exceptions that are linked to later on.
Disclaimer: While I have tried to make this post as accurate as possible, there are some mid year revisions. I also can't be positive all the year ranges listed are correct, especially for pad shapes. In some cases, it is necessary to call a dealership with your VIN number or physically compare parts.
Front Brakes
242x16mm
Smallest Subaru front brakes, found on FWD non-abs Imprezas (93-96). The caliper and bracket are similar to those for early 260mm brakes with a shorter bracket and they use the same pads. These things fit under 13" wheels.
Applications:
93-96 Impreza 2WD.
260x24mm
This is the most common front rotor size before 2000. It was found on many Imprezas and Legacies and uses a single piston caliper and bracket. Somewhere between 1996 and 2000 the caliper design changed depending on model so while the rotors are all the same, calipers don't interchange between brackets. These fit under 14" wheels.
Applications:
90-99 Legacy non-turbo/-GT/-Outback
93-01 Impreza AWD (non RS)
This uses a two piston sliding front caliper and there are three (or more) caliper/bracket designs. One for the 91-94 Legacy SS/TW, an early Legacy 2.5GT/Impreza RS bracket (~96-02), and a Later RS/GT bracket (02+). Post ~98ish calipers are interchangeable between brackets, and will also exchange onto the taller wrx brackets (as long as they are both of the same style). I have also heard that you can even put the later 1-pot calipers on these brackets. They fit under 15" wheels.
Applications:
91-94 Legacy turbo
96-02 Legacy GT/Outback
00-04 Legacy non-GT
98-07 Impreza RS/TS/2.5i
98-02 Forester
This is the WRX front rotor. It uses a two piston sliding front caliper or the Subaru fixed 4-pot. There are two sliding caliper bracket designs: One is the same as the 98-01RS, and the other started use sometime in 02/03 (varies depending on model). The 4-pots are only on the 06-07 WRX in the US, though they were on many older non-US STis and WRXes (the black calipers with Subaru across them). Generally 16" wheels are required with these brakes but there are some 15" wheels out there that work. Also 16x6.5 Subaru wheels do not clear 4-pots.
Applications:
01 Legacy GT LTD
02-04 Legacy GT
01+ Outback
02+ Impreza WRX (including 08, which uses 2-pots)
03+ Forester
Baja
There are three WRX DBA rotors, here is a description from Steve at DBA[
650 was the original light weight WRX replacement rotor4000 - Was developed for production car racing with the 4 pot WRX caliper. (before the USA WRX was released). The 1999 to 2001 WRX had a sintered ABS tone ring mounted on the hub so the mounting bell profile could not be altered to suit the USA caliper. This one is for the rest of the world.
4650 - Is a modified 4000 to suit the 2 pot USA WRX caliper. Only the mounting bell shape is different to clear the support bracket on the USA caliper. Still don't know why Subaru spec'd the two pot caliper.....
What that means is the 4000 rotor will not work with the 02-05 brakes, and maybe not on any car with the abs sensor in the knuckle. It would be best to get the 650 or 4650. The 650 is 24mm thick (same as OEM), and the 4650 is 25.4mm thick (mmm.. beefy. Might have to leave out the shims at first).
Added bonus points: This rotor is also available in 5x114.3 to make it possible to swap an 05-07 STi to the subaru 4-pots for rally. Not sure where to find that rotor but I would start with rally shops.
This uses a two piston sliding caliper similar to the other 2-pots, although brackets and calipers aren't compatible between other 2-pots. 17s are required with them.
Applications:
05+ Legacy GT
Tribeca (5x114.3 bolt pattern)
326x30mm (5x100)
326x30mm (5x114.3)
STi rotor that goes with the 4-piston Brembo calipers. There are two rotors, the 04 has a 5x100mm hub bolt pattern, 05+ uses 5x114.3, although caliper mounting remains the same so you could use 05+ calipers on a 5x100 car with 04 rotors. There were some changes to the caliper over the years that involved some sort of stiffening, so from what I can tell an 07 caliper would be slightly better than an 04.
Applications:
04+ STi
It seems the 08 STi still uses these brakes but the calipers are black with an STi logo.
A note about the SVX:
The SVX has brakes that are about the same size as WRX brakes and the SVX has 5x114.3 hubs. However, up front, the rotor hat offset (how close or far the rotor surface is from the hub) is different from that on other Subarus. The knuckle also locates the caliper bracket in a different position. That unfortunately means that you can't just buy some 05-07 STi brembos or Tribeca brakes or something to upgrade your SVX. I'm pretty sure that in the rear things are compatible with other Subarus.
Rear Brakes
The most common Subaru rear rotor. It uses a single piston sliding caliper, of which there are a few variations. Early Legacy sedans (non-turbo) and Imprezas have a smaller piston than Legacy wagons and turbos, and there are a few bracket/caliper revisions.
Applications:
90-99 Legacies/Outbacks with rear discs non-turbo
93-03 Imprezas with rear discs
04+ non-Sti Imprezas
06+ non WRX or STi imprezas
Foresters with rear discs
Bajas
I think this is on non-turbo 05+ Legacies, and 05+ Outbacks as well.
This is well known as the H6 rear rotor. The caliper is the same as the ~99-04 calipers so many people buy these rotors and the right brackets for a cheap upgrade.
Applications:
00-04 Legacy/Outback non-brighton
SVX (5x114.3)
Bonus points: SVX bracket + this rotor in 5x100 = old style caliper H6 upgrade (probably).
266x18mm
This is the Legacy turbo rear rotor. The caliper is similar to the other calipers but is wider to accomodate the vented rotors. I hear it was also found on the v1 WRX (93-94).
Applications
91-94 Legacy turbo
290x18mm (170mm parking brake)
290x18mm (190mm parking brake)
This is a new rotor size for Subaru (in the US anyway). It uses either a 2-piston opposed caliper or a 1-pot slider. The 2-pot will not bolt up to other subarus without somthing like the Kartboy brackets or having a new backing plate pressed onto the spindle. There are two versions of this rotor, one is for cars with an R180 rear diff which has bigger parking drums.
Applications:
05+ Legacy GT (1-pot)
06-07 WRX (2-pot)
SVX (5x114.3) (only in JDM-land)
Some older non-us spec-b Legacys and wrx/sti models.
Note: The LGT uses a different brake line than older Legacies and Imprezas. So if you want LGT rear brakes there could be an issue there. The line mounts to the caliper at a different angle and from what I've heard Impreza lines will leak. On top of that, the LGT line (and all 00+ Legacy/outback rear lines) is some funky multi-part piece with two sections of flex hose and a hard line that attaches to the trailing arm thingy that won't work on an (pre-08) Impreza. I'm not sure what the solution is to that problem but I think there are some people out there with LGT rear brakes on Imprezas.
316x20mm (5x100)
316x20mm (5x100, 170mm parking brake)
316x20mm (5x114)
STi brembos. There are now three versions of this disc. One for the 04 STi, one for 05+, and one with a 170mm parking brake drum that will fit on any other Subaru with either a 2-pot backing plate or kartboy brackets.
Applications
04+ STi
320x18mm
Hey that's an odd size now isn't it. I was previously wrong with my thinking the Tribeca uses the same rotor as an STi. It does have the same bolt pattern (5x114.3) though. AFAIK, it uses a 170mm parking brake but don't quote me on that.
So, what does that mean? The calipers and brackets should work on an SVX. Unfortunately no front brakes are interchangeable onto an SVX because of the rotor hat back-spacing.
286x10mm
08 WRX rear rotor, which uses a 190mm parking brake and 1-pot sliding calipers. The bigger parking brake makes me wonder if the caliper bracket is not like the older sliders, and if they made the backing plate to accept a 2-pot for simplicity. That would make it much easier to swap rear brembos but I'm really stretching things. Someone's going to have to take it apart and try.
Drums
Some cars have rear drums that are like 9." I don't really know anything about Subaru drum brakes so it would help if someone filled that stuff in.
Some of them are: Legacy and Impreza Brighton models, Some 95-99 Legacy L models, some foresters and I think 02+ Impreza TS and OBS. (I'm not sure exactly)
To swap out drums, at the least you will need new parking brakes, backing plates, discs, calipers, and brake lines. It is usually best to get a whole knuckle/hub/parking brake assembly out of a car with rear discs. If you want to put rear discs on your front wheel drive Subaru, you might have to parts from a 90-94 Legacy, since they might be the only FWD Subarus with rear discs and the FWD rear hubs/spindles/struts/etc are different.
Installing rear Subaru 2-pots or Brembos on a non 2-pot car:
The Subaru and Brembos have the same backing plate, which is different from all the other Subaru rear disc backing plates. So calipers don't swap between the two. Additionally, the STi uses a 190mm parking brake drum. Pretty much everything else uses a smaller 170mm drum. That means if you take a set of rear brembos and put them on your WRX, the parking brake will not work.
However, there are Subaru 2-pot rotors (290x18mm) with a 190mm parking brake hat and Brembo rotors (316x20) w/ a 170mm e-brake so you can put either setup on either car. There are also Kartboy brackets that will adapt the 2-pot calipers to any other Subaru, and since both rotors are available in 170mm parking brake variety, you can swap either one onto any other Subaru. Here's a thread about fitting the brembos to other cars with the new Kartboy brackets and DBA rotors.
Here is the rear brake redux, which has more information about the older rear brakes that came on STis and fancy Legacys in Japan.
Some D-plate numbers
The Friction Materials Standards Institute (FMSI) is an association that assigns numbers to different pad shapes that are used as a guideline for pad manufacturers to refer to, and bring a common numbering system to the brake pad aftermarket. Virtually every pad manufacturer will either use the FMSI number in their numbering system or have a readily available interchange to cross-reference their part number to the FMSI number.I should note that the caliper bracket, and not the caliper, is what determines pad shape. So while there are a few different pads, in some cases the calipers are the same.
Front 1-pots
1990-1995 Legacy: D470
1996-1999 Legacy: D722
1993-1996 Impreza: D470
1997-2001 Impreza: D722
Front 2-pots
1991-1994 Legacy Turbo: DB1219?/ D563
1996-2002 Legacy: D721
2002-2006 Legacy: D929
1998-2001 Impreza RS: D721
2003-2007 Impreza: D 929
1/2002-7/2002 WRX: D 721
8/2002-2005 WRX:: D 929
See this article for clarification
Rear 1-pots
1990-1999 Legacy: D1186
2000-2004 Legacy: D1379 or D770 (I think they're the same)
2005-2008 Legacy 2.5i/outback:
2005-2008 LGT:
1993-1998 Impreza: D1186
1999-01 Impreza: D1379/ D770
2002 Impreza w/ rear discs: D1379/ D770
1/2002-10/2002 WRX: D1379/ D770
11/2002-2005 WRX: D1004
2003-2007 Impreza: D1004
2006-2007 WRX (and previous Black 4/2-pots)
Front: D1170/D460
Rear: D461
STi Brembos
Front: D 1001
Rear: D 961
I should probably put all the car/rotor/d-plate combinations in a spreadsheet or something. Outback should be the same as Legacy. I'll look into Forester and Baja stuff later I guess. There are a couple of things that I'm not clear on, like exatly when caliper/bracket designs changed between cars or which 00-04 Legacies got the 294mm front rotors. I might also be wrong about some of the forester front brakes. Also I've been meaning to add brembo or oem part numbers for the rotors or something like that.
Coming soon: Pad shape clarification courtesy of an EBC spreadsheet I was recently sent.
Here's a handy guide of all the brakes that came on recent Subarus:
Yes they're very similar but I've heard varying reports that the pre-02 and 03+ calipers and brackets don't interchange. There are also at least two different part numbers for the newer calipers and another new revision that recently occurred.
Also, over here only the 06-07 WRX has the 4-pots and the rest have 2-pots with a taller bracket for the 294mm rotor. The caliper in that picture is from an 02 WRX.
Actually I was incorrect about the year range. For front 2-pots the 96-02 calipers are all the same. But from looking more closely at your pictures it seems you have 91-94 turbo legacy brakes.
The difference is how the caliper mounts to the bracket and also the pad shape. Here you can see how the brackets differ:
96+ bracket is on the bottom
The 96+ caliper looks like this:
Raybestos vs. Centric vs. Brembo vs OEM
Posted
I'm also happy with the Axxis Ultimates. Great performance, but yeah, tons and tons of dust. That's something that comes with performance though.
If you're getting uneven deposits on the rotors it means the pads are getting too hot. The 00 outback is a pretty heavy car and they didn't upgrade to the bigger front brakes until 02 or 03. So skip anything from a parts store like raybestos and go with a more performance oriented pad. Some options are:
Axxis Ultimate
EBC Red or Yellowstuff
Ferodo DS2500
Hawk HPS or HP+
As for rotors, the cheapest thing that is straight is really all you need. DBA makes nice stuff, but it's not really worth the $40-80 extra over a blank. Centric and brembo make good rotors so I would just go with one of those those. I've used importrp.com a few times and they have good prices.
