kevinC
Everything posted by kevinC
DIY Struts R&R?
kevinC replied to blitz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I used some short lengths of chain and some all thread. I had the problem of the spring compression tools being to bulky to fit properly. -
I was thinking maybe the normal wear from the clinder walls of the compressor and possibly other wearing items inside the compressor have slowly plugged the filter over the last 200,000. Got to try something or I am going to lose the clutch or something else from exsessive cycling. I have a new 30 pound cylinder of 134a and am ready to try something.
The bigger hose on the compressor(hot gas) is slightly cool and slightly sweating. The small line(High pressure liquid) is very hot. Seems to be worse after long idles. I think the evaporator is turning into a big block of ice. I think I will try replacing the filter at this point. Also checked and cleaned the coil through the blower motor resistor hole, everything seems to be clean now. I think there has to be a restriction somewhere, I have never seen a unit equalize so slowly after shutoff. Has to be the filter or the expansion valves. At least I know the check valves are working great inside the compressor.
When I Rev the engine up the high side wants to climb up in the neighborhood of 350+ while the low side sucks down until it cuts out around 30. At idle it will short cycle with the blower at low speed but seems to do alot better with the blower speed on max. With the blower at low settings it will short cycle about ever minute, sucking the low side down till the switch is made. With the blower at high speed it will run ok at idle. I just finished cleaning the evaporator coil and it was about 30% blocked. This may help but I think either the filter is clogged or the expansion valve is not functioning properly. Also once the ac is shut off how long should it take to equalize? Also it will stop cooling completely if I let it idle for a long while. I think it is icing up and triping the thermo switch. I also apologize for starting a new thread but I couldn't find the old one.
As I drive down the road the a/c cycles on and off about every three seconds. I shorted out the low pressure cut off switch on the filter dryer and the problem is still there. I suspect it might be the evaporation thermal switch but I hate to pull out the evaporator to check this. Has anybody had similar issues. 96 legacy 2.5. Also if I turn the blower on high and roll down the windows it seems to real help the problem. I have also checked 134a pressures and everything seems to be normal.
The black connectors when hooked together will flash your codes. If no codes are logged there will be a steady flash. If the light goes dim it sounds like power is being limited to the ecm. The ecm has its own power supply inside. (think 12 to 5). the ecm pulls apart fairly easy. you might look for cracked or melted solder joints on the ecm. The ecm is under the dash by the connectors. gold box 4x6 . also ground to the ecm. Also do you have a good 14volts while the car is running. check all body grounds also. Good luck ((1990 legacy 228,000))
IT shakes like a paint mixer. I had to pull it with a set of pliers as hard as I could to get that sucker out. Also remove you fuel tank cap or it will pressurize the system and bleed gas forever. I had to remove the spark plug for that cylinder to remove all the gas that had made it into the cylinder. The car had set for two days and still sprayed me with gas. had old cloths and a good set of glasses. entire job took less than 10 min.
The boots keep out contamination(dirt,water,brake dust). the pins should be cleaned very well and then a small amount of anti seize for lubrication. and if i remember correctly the boots have different ends. you need to put the correct end in the caliper first. Then slide the pin in. if all is working well the pin should easily slide back and forth through the caliper. if the pin binds or sticks your pads will wear uneven and worst case maybe warp a rotar.
