kevinC
Everything posted by kevinC
My type of MAF was JECS(black) it is supposed to have a more problems than the hitichi. Also have you tried to monitor fuel pressure. I ran about ten feet of hose from a tee I put right after the fuel filter. Got the hood to close with out pinching it and ran it inside the drivers side window. Got a lot of strange looks but it worked well.
MAF SENSOR, had similar problem. ran great 99% of the time and about once or twice a week it would act up. usually just die or if i could keep it running it would act very chuggy(like on 2 cylinders). Soon as i would turn the key off and then back on it was fine for days. (90 legacy 227,000 miles) HAD a post recently and legacy 777 steered me in the right direction. also no codes would be thrown.
91 legacy AC
kevinC replied to johnnyk's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have had the expansion valve leak on 1990 legacy, it would leak out overnight. it is located inside the dash. and also there is a small threaded plug on the bottom of the compressor (calsonic compressor)that was barely leaking. Use soappy water and also look for oily spots around the lines and check the compressor clutch to see if it is wet(oily). -
Strangly enough mine died alot around long or sharp right hand corners and also alot at lights(highway lights are he worst. nothing like people zipping around you at 60 MPH) it would also die just going down the highway. I think it had to do with the vibration or maybe the way the body was flexing. I have only driven mine a couple of days and have not really tested it throughly. But the MAF sensor located right after the air filter (should have 4 or so wires going to it) seems to have been the problem. There was a broken solder joint on the small board that the sensor plugs into. Also does it start right back up.
Brake Questions??
kevinC replied to a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If you don't mind the extra money I would go with stock. -
Have been chasing problem for several months. Have changed fuel pump, knock sensor, purge solenoid, drained fuel tanks, monitored fuel pressure for weeks. I have 250,000 miles on this car and have never really had any problems to speak of. Then I got the bright idea of pulling of the intake and cleaning it. I do not know if I caused the problem or it was a coincedence. But now about ever 30 miles or so it just dies. if I catch it just right i can prolong it by thottling the excellerator but just for a few seconds. Then all i have to do is turn the key off and back on and it is fine for days. Fuel pressure stays at around 35psi during the events so i have eliminated fuel. The car runs great except for these episodes. With gas prices as they are i would really like to keep it. But this car really is a hazard. any help would be greatly appreciated.
