Everything posted by wrongturninwv
Valve cover bolts
What kind of socket do you use on the valve cover bolts on the 95 2.2 engine. thanks
Missing Hole !!!!!
Thanks for the great advice guys. Was just worried about running without EGR. I typed in on the net ( can you run a car without an EGR ) and read some not so good news. Like burning valve seals, and too much heat in the piston chamebers and rough running. And than some people say they have no problem at all. One way or another its gonna run. Its too hot to pull it out again and my boy cant wait to drive it. lol WE put TOO much work in this for it not to run. We pulled this engine out by hand with a treated 4x4 post and a cable in 90 degree heat and put the other one in the same way. Im sure after this my boy will learn to check the oil so he dont blow another one, cause the next engine hes on his own. Im getting too old for this. thanks guys
Missing Hole !!!!!
Pulled out a blown 2.2 out of my sons 95 Impreza and put another 2.2 engine in. Got everything hooked back up and last thing was the tube from EGR valve. I found there is no hole for the other end of the tube in the bottom left side head. Did they make some different kind of set up for the EGR valve on some 2.2 engines ???? Im stuck now big time. Need some help guys. I dont think I can plug EGR and run without it. HELP !!!
Intake Manifold Torque 2.2
95 Subaru Impreza 2.2 intake manifold torque. Need to know what to torque the 8 bolts in ft lbs at and where to start.Picture I have of it is not to clear. thanks
New Intake Manifold Gaskets ??
Had to remove a intake manifold on a 2.2 engine. Need to know if you use a sealer with new gaskets. If so what is the best to use. thanks
Rear Brake Line - 96 Outback
Thanks guys for all the help. This is on my must do list. Will get to it this week.
Rear brake line burst above gas tank on passenger side. Can not see up in there. Need a quick way to repair. If I need to pull gas tank to get at lines please explain how. Looks like its gonna be a big job. Also how do I beed rear with the ABS,anything I should know. thnaks
Wheres the parts girl ???
There was a girl on here that sells new Subaru parts,is she still around,and what was her name.
Pulling an engine-95 Impreza
Thanks Gary,not the first time you gave me great info. I got a great deal off Ebay on a zero mile 2.2 engine thats on its way home for the price of $300.00. A man in Ill bought it from a Subaru dealer years ago (still in crate) to put in a small one man plane. Never went ahead with his project so now going in my sons car. Give my some tips on firing up a new engine so I dont get a dry start and mess it up. Some day send my you number. Im in WV too and alwasy running into Subarus and parts for sale. thanks
I am pulling a 2.2 engine out of a 95 Impreza with an auto trans. Maby I can get some tips here. Everything disconnected but trans and motor mounts. Where is the best place to hook a short chain to block to pull the engine out ??? Also I dont see many bolts that hold trans to block,how many are there. Also what will I need to remove converter from flywheel when I split it apart. Need someone thats been there did that. Thanks
96 outback overheating
I have a 96 legacy outback with the 2.5 engine and its automatic and i was wondering why it keeps overheating it seems like everytime i drive for about 3 to 4 hours it overheats when i check the oil it is full when i check the radiator all the antifreeze goes right into the recovery tank when i let it sit to cool all the antifreeze disappears. I put a new oil filter on and put new oil in, i changed out the temperature control swich and the cooling fans work, i put a new radiator cap on and changed the antifreeze, then we burped it twice. no oil leaks or water leaks no where, no smoke no blown head gaskets everythings good on it beside the antifreeze disappearing and overheating. if any1 can help me thanx
What bearing ???
2001 Leg Outback 3.0 H6. Need to know if the top pulley with the bearing inside that the main belt rides on that runs alt, power steering is interchangable with any other Subaru pulleys. Also if any of you have one let me know. thanks
96 Outback rain gutter ???
Maby someone here did this before. Replacing right rear glass in a 96 Outback. How do you get the trim or gutter off that sits above the glass ? I pulled down some of the head liner and from what I can see in the small holes in the upper body it almost looks like rivets. Anybody know how ??? thanks
96 Outback Rear Bumper ??????
Can not thank you enough !!! I looked and felt around under that car for an half hour like a nut.. I would have never dreamed of looking on top for bolts hidden bolts. I thank you !!!
Fixing up a 96 Leg Outback wrecked in rear end. Bumper cover was ripped off and steel bumper that was under cover was crushed in the center. Can not seem to see any bolts under car to remove this. Is the steel bumper thats under the cover welded on or is it part of the body frame it self ????
Torque for castlenut
I HAVE A 2001 SUBARU LEGACY OUTBACK H6-3.0 AND I WAS WONDERING WHAT IS THE TORQUE OF THE CASTLENUT ON THE CV JOINT? THANX:rolleyes:
01 Legacy Outback Rear Hatch Fills w/Water! Oh no!!!
2001 Leg Outback 3.0 with 2 sunroofs. Same problem here. I thought it was only after a spray car wash but was wrong. Hope you find find problem cause it rotted out the bulb socket in my tailgate allready. good luck
Front Wheel Bearing Problems
2001 Subaru LEGACY Recall ID from NHTSA: 00V391000 Auto Recall Date: 11/21/2000 Vehicle Component: STEERING:LINKAGES Estimated Vehicles Affected: 1977 2001 SUBARU LEGACY Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES. A CASTING FLAW IN THE RIGHT FRONT BEARING HOUSING COULD RESULT IN LOSS OF STEERING IF THE CASTING FLAW SHOULD EXIST IN THE TIE-ROD ARM. Defect Consequence: THIS CASTING FLAW COULD CAUSE GREASE LEAKAGE, FRONT WHEEL BEARING FAILURE DUE TO LOSS OF GREASE, OR LOSS OF STEERING DUE TO TIE-ROD END SEPARATION. Remedy: DEALERS WILL REPLACE ALL FRONT BEARING HOUSINGS WITH A LOT NUMBER OF OF15. Notes: SUBARU OF AMERICA, INC., WXY-82 Also one out there for the left side steering knuckle on the 2000 Legacy.
Component Description: 18. STEERING:LINKAGES:KNUCKLE:SPINDLE:ARM Bulletin Number:010101Bulletin Date:Jan 2001Vehicle: 2,001 Subaru OutbackSummary: SUBJECT REGARDING INSPECTION PROCEDURES FOR POSSIBLE REPLACEMENT OF THE RIGHT FRONT SPINDLE HOUSING. ( NHTSA ITEM NUMBER - 616344 )
2001 Outback 3.0. Right side wheel bearing problem. First time replaced the bearing was about 5 years ago and used Subaru part. I got about 2 years out of that one. The next time I went with a bearing from Advance and that one lasted over 3 years. About 2 weeks ago I had another Advance bearing installed and I am getting noise out of this one after just 2 weeks of driving. Eveything was done at a shop and now the guy cant get me back in till next Wednesday to check it out. I did some reading and found Subaru had put out a bad right side steering knuckle on the 2001. Maby this is whats making the bearing go bad.Has anyone else had this problem with bearings and does Subaru replace these bad steering knuckles at no charge ????? I also would like to know if the steering knuckle is the same on all 2001 Outbacks no matter what the engine size. I have owned Subarus since 1980 and never had a wheel bearing problem on one of them. Why just the right side all the time ??? Need some answers. thanks
95 Impreza LX
I have a 95 Impreza Lx wagon 4x4 with the 2.2 engine. I would like to know if I could put a 2.5 from an 96 4x4 Outback wagon in mine without any problems. What all would have to be changed such as would my trans mount up and would I have to chang wiring or the computer box ??? Any of you guys done this before ?? thanks
Brake and Battery light come on and off
2001 Outback H6-3.0. Car runs fine but batt and brake light flicker on and off sometimes. No starting or brake problems. Breaks replaced last month. Good belt and idler bearing. Battery about a year old. Anyone had this problem please let me know what you found. thanks
Mc Intosh CD Player
2001 Outback. Anyone know what the error codes mean on that brand name CD player ? Ran a cd cleaner in the player but did not solve the problem. I find that I have trouble more in the winter when its cold outside. It will not play a cd till it gets pretty warm in car. I get code er 3. Its always been a fussy cd player on what type of cd's it plays. Also is it very hard to take system out and clean the laser myself ? Went to Mc Intosh web site but it has nothing on what all the error codes stand for. Thanks
Cv boot replacement
Junk. Some called a Quick Boot. Some glue together some screw together some snap together. A sort of hard boot that will not flex enough when wheels are fully turned. They will break open again and you will lose the grease you have to buy extra. Not worth your time or money.
Cooling Fan Not Working
It was the Coolant Temperture Sensor !! Not an easy thing to find or get at. Its buried under a bunch of other wires. If anyone else has problem finding it, my best way to explain is follow the hose from your PCV down to where it clamps to intake manifold and you will see a brown plug under a bunch of wires that goes to the CTS on your right. A 17mm deep well socket gets it out. Getting the connector off was my biggest problem. A job for someone with small hands to get in there. But now the cooling fan works. Thanks guys for all your help. This site has saved me hundreds of dollars ( that I dont have ) in repairs if I had to take it in to a shop and have the work done on my cars. My son is happy and so am I, and im happy my sons first car is a Subaru. thanks for all the help:banana:
