Champion spark plugs
I'm running autolites in my wagon. they work just fine and have been for about 3000 miles now and counting
Shifting into First....GRIND!!!!
From the sounds of it I would say that the blocking ring is very worn. it wont be cheap
Speed Sensor Wiring
the manufacture date is July 1983, so it could be an '84 depending on when the cut off date is. its a manual, 2wd 5spd I dont know about the lifters i think the wires were black with a red strip and yellow, i'll check this tomorrow. Thanks
Speed Sensor Wiring
ok, it could be an '84, i checked the tag in to door and it had the date 7/83. The speedo is working. i am getting code 22, when i had the dash apart to fix some other stuff, i noticed that the 2 wires coming off the back of the speedo werent pluged into anything.
Speed Sensor Wiring
Hey everyone, I have an '83 GL wagon, the vehicle speed sensor is unpluged and i havent been able to find where it plugs in, or which wires coming out of the ECU plug into it. Does anyone have a wiring diagram for this? Thanks
Bad 4sp Trans ?
if it goes away when off the gas, i would say its the inner cv joint, I just bought an axle from car quest and it had a bad inner joint
Illegal clutch release.
the only other thing i can think of is the pressure plate has some bent fingers
I would check the splines on the transmission input shaft
Front axle replacemet
Thanks, whit those instructions it was easy to do it. but now i have another problem, when i took it out for a test drive, something started ticking when on the gas, as soon as i let off it stopped, i went back through everything i had done, i couldnt find anything, so i took it out again, and it was doing it again, the faster went the faster it ticked. I was thinking this is the inboard joint. What do you guys think?
will i need to replace the castle nut?, i vaguely remember hearing somewhere that your suppose to replace it if you take it off
Hey all I'm going to be replacing the front axles in my 83 wagon this weekend. I have never done this before... is there anything i should know before i get started? Thanks
Classic Brat?
All of the cruise-ins i know of say its 30 years
CHP Cut me a break in my Brat.
Reminds me of the time me and some friends bought an 84 hatchback and cut the top off rear of the door frames and took it out for a spin to get parts, and on an on ramp my friend was doing about 65 on when it was marked as 35, we got drifting a bit and for a few seconds we were on 2 wheels good times
Trouble code 22
I went through the wiring and found that the sensor is unpluged, does anyone know where it plugs into?
What's so special about LSD? not the drug
Limited slip help give you traction, it helps keep the tries turning at the same speed
Sube Wagon Kevin
