9
the front driver side is #2 rear driver side is #4. if in fact the other 3 have good compression then i would think it is either a valve or rings in that cylinder. and the leak down should show that. and those things are pretty rare. more common is for it to jump time. and the good news it that it easy to fix, no internal damage. if you remove the timing covers for the cam sprockets on both sides and turn turn the engine over by hand, you can line up the timing marks on the cam sprockets to see if one side jumped. i'm not sure if you should do one before the other.
given all the codes i would check the connectors. but if the intakes need to be swapped the wiring connector pins may be aligned differently and that will correct everything. P0130 Front Oxygen Sensor Circuit Malfunction P0136 Rear Oxygen Sensor Circuit Malfunction P0500 Vehicle Speed Sensor Malfunction P1100 Starter Switch Circuit Malfunction P1101 Neutral Position Switch Circuit Malfunction P1120 Starter Switch High Input P1121 Neutral Position Switch Circuit Low Input P1540 Vehicle Speed Sensor Malfunction 2
i think, if subaru had put the rad cap on the passenger side of the radiator where the top radiator hose is located, i think there would be fewer problem. but you still would have to fill it slowly. the last time i did it i used a 3/8'' tube and i siphoned the coolant out of the jug which was sitting on the passenger strut tower into the radiator. this process was so slow, it think it gave the coolant time to ''flow'' down into the engine with out bubbling over. anyway, i think filling slowly is one key part of the process. FWIW
there is a good thread describing ''cleaning'' the hlas with pics i think. some thing like removing them and soaking them in some solvent or very thin lubricant and working them by hand until the dirty oil stops coming out. and then doing it again in 10w-30. i don't really know, can't remember. but not being able to turn the cam by hand does not sound right. you didn't reverse some thing did you.
this may be a matter of vocabulary. thumping is not a typical failure symptom of the center diff. however, binding in tight turns is. and different folks use different terms to describe binding. to check for it, drive at idle in slow tight turns, all the way to the tightest turn you can make. if the car is binding it will not want to go with out giving it gas, or if it does it will buck, shutter, jump, or maybe thump. but thump is not a term i would use to describe it. thumping at take off going straight is going to be some thing else. drive shaft probably, maybe. i would install a used shaft , if needed. look here : www.car-part.com and or place a wanted ad in our classifieds.
sounds like it could be the drive shaft thumping. is it an auto trans?? if so, installing the FWD fuse may relieve the issue temporarily. you are going to need to crawl under there and have a look. shake and wiggle the drive shat, it may be the carrier support bearing. while you are checking it out, look for seepage at the head gaskets. looks like a nice car. congrats.
i used duck tape to make sure my socket stayed on my longest extension. then i put the bolt in the socket and used a litte more tape to keep it from falling out. the bolt has a flange, i think, and just a little bit of tape folded over the under side will keep it in place. then after you start to tighten the bolt you can pull the extension and socket away from the bolt. as long as there is more tape on the socket than the bolt you should be good.
the knock sensor is certainly part of the problem, how much i don't know. and until you correct that you won't know. plus i'm pretty sure the car goes into some sort of fail safe mode when the knock sensor fails. the knock sensor does not have to be a subaru part, you might be able to find one online for less, $60 - $70 maybe. but if you don't have the money it doesn't much matter. using one off of a ''wrecked'' car might be a solution, but a risk as well. i say a wrecked car because the assumption is that it was running pretty well when it wrecked. are there any u-pull-it yards near you? if you can get one cheap enough it might be worth a try even if the car isn't wrecked. DO NOT over torque the bolt when you install it. you can crack the sensor and then it will be bad as well. sorry to hear about your job, good luck.
i don't know. it's new and i have only driven it ~500 miles but i have no indications of having traction control. although i don't really know what it is or what indications there would be inside the car. my only glimmer of hope with this code is that it is a circuit problem. but i don't know where to begin. thanks.
does any one know what or where the engine torque control circuit is ?? i have checked the connections at the rear of the engine. sprayed them out with contact cleaner. i don't think this code is an uncommon problem during a ej22 swap but i can't find the cause. i don't even know what it is referring to. is this referenced in the FSM, p1104?? please help. the car runs great but the code comes back every other day.
my impression of TCUs is that there is very little difference between them. however they are computer circuit boards which can be programed. so i don't really know. but i doubt seriously you will cause any damage by installing the wrong one. if the wire connectors match up and as long as both cars are of the same trans type, awd vs. fwd, i think you will be ok. and if you can try it before you buy it, all the better. if you have a choice, i would tend to stick to cars of a similar year style, size and weight. i have swapped a 96 Lego L wgn into a 95 lego L sedan, and into a 97 lego GT wgn with no ills what so ever. also with no apparent improvement or change. one note: the 95 vs. 96 have a different box and bracket, but the boards inside are the same, so i swapped the boards into the other box / bracket. just because the bracket is different doesn't mean the TCU is.
are you worried about a one time event, it's in a ditch now and you have to pull it out? or are you thinking of off roading and planning ahead for the day you get into something you can't get out of? the manner of the extraction may be more important than what you hook to. if you ''jerk it'' out you may damage something regardless of what you hook to. on the other hand if you slowly pull or ease it out it probably doesn't matter if it is hitch or hook. i have read about guys using high end tow straps to ''snatch' or ''jerk'' a car out, but having no experience in this i would be reluctant to try this with my car or to recommend it.
