OB99W
Everything posted by OB99W
That doesn't answer the question of whether "conditioner" (stop-leak) has been used, and to what degree. I'd assume the dealer has been adding that stuff to satisfy Subaru's requirement for head gasket leakage "preventive maintenance". Normally it's not an issue, but if someone isn't diligent about getting all the air out of the cooling system, the "conditioner" can harden and clog things internally. I certainly hope coincidence explains your problems, but I'm not convinced of that.
If the issue is mainly ease of availability, and not so much pricing, online dealers sell the OEM spin-on filter for about $23 plus shipping charges. You could probably have one delivered to your door in a few days. The quality of aftermarket filters is variable -- some may be up to the job, some not. If we're talking about an '03 GT, I personally wouldn't risk the trans versus saving $15-20. However, "Ya pays yer money an' ya takes yer chances".
That's the general idea, but even if they open at 212 degs F or so, it won't determine correct operation. To do it properly requires a thermometer that covers the opening range, and both the thermometer and thermostat should be suspended in the water, not touching the side or bottom of the container. Heat the water, and note at what temp the stat begins to open, and at what point it's fully open. If working correctly, it should start opening a bit under or at the rated temp, and be fully open by a few degrees above rating. If it's not fully open by a maximum of 10 degs over rating, it should be replaced.
Agreed, it's definitely worth looking at the transmission cooler lines. They run from the trans to the radiator and back, so a leak in one of them could certainly put ATF in the area mentioned. The leak might be substantial and easy to spot, or could be a small/slow one that finally made you aware of it when the fluid got to the exhaust. Fluid can travel due to gravity, car motion, etc., so the source may not be obvious at first. Especially if the leak is small, you may have to clean the area in order to more readily see it.
If the noise changes when a fuel injector is disconnected, it doesn't necessarily indicate the injector is the source. By stopping combustion in a cylinder, the high pressures associated with it are eliminated. Therefore, a change in noise level or characteristic when an injector is unplugged could also point to piston (slap), connecting rod (either end), etc. There's some pretty good engine noise diagnostic info that might help localize the problem here: http://remanufactured-engines.com/page4.htm
The only two simple (non-miraculous ) explanations are that either the tach is non-linear or the speedo is. Since you've verified the tach's accuracy with other instruments, that leaves the speedo. You said "i went by a speed sensor for the cops the other day and i regestered perfectly.....25 in a 25", but that doesn't prove indicated 60 MPH is accurate. If there's a stretch of highway in your area that has mile markers and is relatively free of traffic sometime during a day, you can verify the speedo. Doing a constant 60 MPH, measure the time between mile markers; it should be exactly one minute from marker to marker. If you can hold 60 over several miles, the accuracy will be better. (For safety, this should be done with a second person in the car doing the timing.) Any discrepancy from one minute per mile will indicate speedo error.
Let's assume for the moment that the picture represents actuality. If that's the case, engine RPM at 80 MPH should be 4/3 of that at 60 (in 5th gear at both road speeds), or about 2200 RPM (not "3500-3800 RPM"). If the RPM reading at 60 is accurate, then 3500-3800 at 80 indicates a really badly slipping clutch at the slightly higher road speed. I'd be more inclined to think the instrumentation is wrong.
It will totally cut the supply to that cylinder, if the injector isn't leaking at all. I assume you're attempting to determine whether this will result in better fuel economy. As Nipper pointed out, the 4th cylinder will be a load on the engine. Cars that drop cylinders to improve fuel economy address the valve train as well as the fuel, so the unused cylinders aren't pumping air from intake to exhaust. Also, injecting large volumes of air into the exhaust can have "interesting" results on the engine management system, etc. If you're still inclined to experiment, I'd suggest at least wiring a switch that can be operated from the driver's position to the injector. That way, you can try cutting the fuel only above the point that vibration seems to disappear, and be less likely to cause damage.
I appreciate your concern over the qualifications of some "professionals"; it's one reason I participate in this forum.However, this is a situation where it's not practical to DIY. See: http://www.bacharach-inc.com/refrigerant_recovery_faq.htm http://www.professionalequipment.com/refrigerant-recovery-tools/ While I don't want to be the "refrigerant police", here's what the EPA has to say about it:http://www.epa.gov/Ozone/title6/608/608fact.html
