lytnin88
Everything posted by lytnin88
I have an '03 Forester with 68K miles on it. No major problems so far. Factory installed disc brakes didn't last long, though. Having said that, I wouldn't buy a Forester if I had to do it again. As was mentioned, doesn't make a lot of sense in Southern CA. Depends on the weather and road conditions where you are. As was also mentioned, not much leg room in the back. But, I think it's a very well made vehicle. Problems with earlier Foresters seem to have been rectified by '03.
Oil Filter ?
lytnin88 replied to rweddy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Why do you need Subaru filter? WHy not get Fram, or Purolator? -
You should be aware that just removing the plug will not completely drain all of the auto trans fluid. I was able to drain about 4 out of 10 quarts doing this on my '03 Forester. But if you repeat this procedure 3 times, running the engine in between drains, it should be a pretty good flush. On my car, you can remove another quart or two by removing the ATF filter, which looks like a motor oil filter. The alternative to the above procedure is taking it to an auto trans shop, where they have a special machine that sucks out the old fluid while replacing it with new. There is another procedure for the do-it-yourselfer, which involves opening up the transmission fluid line at the radiator, draining the old fluid into a bucket (with engine running) while replacing it with new fluid. I haven't tried this, and it seems a bit risky.
I have a 2003 Forester with 67K miles on it. Owner's manual doesn't say anything about when to replace 02 sensor. Should I just wait until I get CEL? Also, when should I change spark plug wires? Still have factory wires. I checked resistance recently when I changed spark plugs, and all wires are between 6.1K and 7.9K ohms.
I removed the glove compartment of my '03 Forester today to replace the air filtration filter and--lo and behold--there was no filter installed. I bought the car new and had it serviced once at the dealer, so either the filter wasn't installed at the factory, or the dealer took it out and didn't replace it when I had the car serviced at about 35K miles. It currently has 67K miles on it. By the way, Subaru recommends that this filter, which filters the cabin air, be changed every year or 7500 miles, which seems a bit excessive to me. Anyway, I installed the new one. Let's see if it makes any noticable difference.
The auto transmission fluid cooler, which is located below the radiator, has an inlet and an outlet hose between it and the tranny, but I don't know which is which. They are at the same height; one is on the driver side, the other on the passenger side of the cooler. If I guessed, I'd have a 50/50 chance of being right (or wrong). The reason I'm asking this question is I'm planning to do an ATF flush, which involves disconning the return line and letting the old fluid drain into a bucket while replacing it with new fluid.
I have a 203 Forrester with 65K mi. Had a major service at dealer at 30K ($500!). They didn't change auto trans fluid filter, which looks like a small oil filter and is mounted next to AT drain pan. Does this ever need to be changed? Also, I need to change front and rear diff gear oil. Should I use synthetic or petroleum based oil? Thanks to Sean in N. VA for his response to my previous question.
