one eye
Everything posted by one eye
  1. So there was snow, and slick trails, and broken cars.............. here are a couple pics from today There are some vids that Ill post up later.................... Jeff
  2. Rick and I got our cars already, this week has been one hell of a week, or a bad week at that, it will be nice to doing something to get my mind off things a bit.................... looking to get into the snow............. Jeff
  3. Ya still got it...... Looks like snow up there this could make for a really good run........... Jeff
  4. It has rained about 4" in the last 24 hours, and on Saturday the snow level is to drop to 500ft, It should be real nice wheeling up there for us..... Jeff
  5. Bumpity!!!!!!!!!!!!!!! Jeff
  6. still sore about the last rund I see................ sorry I understand... Hearts Brian, Hearts................ happy valentines day BTW....... Hearts.......... Jeff Jeff
  7. I would put money on it that your intake manifold gasket is leaking, it will flow down and leak off the bottom of your head right next to your exaust, 4 bucks and you're back in bussiness................ Jeff
  8. Well since a few of us have been having trouble with our rigs or building new ones I think its time to get back to Wheelin..................... Feb 25th Walker run meet at GI Joes Parking lot at 9 am Leave by 9:30 Jeff
  9. So Rick and I resealed and EA82 out of an 86 GL wagon, did everything just like I always do had the heads machined by my local Napa, got new HG's intake manifold and exaust gaskets. we put it all back together we got it in the car and it was ready for service but its missing on #3 we put all new plugs in it, plug wire went through 3 different distys, one of witch was on ricks everyday car, 3 carbs, 1 intake, 2 coils, checked and rechecked the T-belts, checked the timing on the disty, its at 8* BTC, 170psi on the compression, took the valve cover off to make sure valves where moving, checked all the fuses, and still it is missing on #3 the valves where even ground and reseated, I have no clue what the heck it could be at this point...............any help would be good, BTW it is an carbed EA82 with a stock carb on it.......................... Jeff
  10. Post up a pic or 2 of your lifted rigs and the specs of it for 2012!!!!! 8" Jaw lift 31x10.50x15 TSL Super Swampers EA81 extended Radius Rods 6 Lug Welded Rear end Jeff
  11. So here is the lifts on the cars, We ended up doing two of them, Cant wait to see them in action....................... http://www.ultimatesubaru.org/forum/showthread.php?t=129553 Jeff
  12. one eye replied to monstaru's topic in Off Road
    Ok sounds good............. Jeff
  13. one eye replied to monstaru's topic in Off Road
    Im in................ Skylar you should come up this weekend if you got time we can fix you all up if you want Jeff
  14. So We got it it was one of the plugs that are a main wiring harness, just over looked it about 200,007 times good to go now............... Jeff
  15. I have this same thing going on on a car right now, It seems to be a Fuel Pump relay, only problem is Where the hell is it, the one Im working on is a 91 but everything is the same as what was going on in the first post......... just need the location on the fuel pump for a 91 Loyal book says its under the Drivers seat but I dont want to have to tear the carpet up if I dont have to.............. Jeff
  16. one eye replied to Skylar's topic in Off Road
    Right on I just got internests back today, sure looks alot better on my lap top instead of my little phone............ anyways hope they are working out good for ya!!! and welcome to the NWWO.............. Jeff
  17. Any one From the NWWO Group is welcome to come and help!!!!! Jeff
  18. This Friday It seems that There are going to be two new Wheelers getting set up, there will be a new thread and pics with whats going on real time as we do it, Should be cool, Lookin forward to seeing them up in the hills getting used!!!!! Keep an Eye open in the offroad section on 01/13/2012 thats the build date......................... Jeff
  19. one eye replied to monstaru's topic in Off Road
    Rick Pat me and Josh are in!!!! not sure Ill bring butters.......... Ya I probably will bring Butters............... Jeff
  20. one eye replied to subaruglkid's topic in Off Road
    you will have to drop the whole front of the car 2" on an EA81 they cant take the 2" over stock tweak they break axles instantly, as for the rear you can just jack up the rear Torsion Bar then you can fit 27's with out cutting for the most part................ Jeff
  21. one eye replied to subaruglkid's topic in Off Road
    I have an 8" lift on mine and 31x10.50X15 TSL Super Swampers, I didnt cut much at all but I extended the Radius arm 1.25" and got the perfect offset Tire, I have this lift on and EA81 car though, EA81 motors are great I put them in all my wheelers but EA81 Axles are very weak like scott said, also The Trans's are apt to loose Reverse, Ive been through 3 of them in my 82 Brat. There are a ton of things to change over to get it to work right with 31's but it can be done by all means , just do your reserch and youll be able to find a lot of what should or needs to be done............... Jeff
  22. Ya that was a Pain in the .............. Rick got the worst of it......... Jeff
  23. Then I ran into him head on.............. :/ Jeff
  24. And this is where I pulled a Jeep with 35's out, Way to go Woody Bet you wish you still had your Subaru.......................:-p Jeff
